Question about Dewalt 18 Volt Compact Drill Kit
Dewalt dc920 repair instructions chuck
How do I remove chuck to replace broken chuck tooth---one of the 3 bit grips?
  • HOLLYWOODBOI Feb 10, 2009
    I have the same problem and came to this site for HELP!!! I tried your "SOLUTION" and Now MY Damn Drill IS FLIPN BROKEN!!!! Check what you Post before hand so that Others that have a $300 drill dont destroy their EXTREMELY IMPORTANT TOOLS By YOUR ADVICE!!! YOU PEOPLE ARE TERRIBLE JOKES!!! Now what do I tell the kids when I Lose Money and Have to go Out and BUY Another Drill because of YOUR INCOMPETENT SOLUTIONS?!?! IM ABSOLUTELY FURIOUS!!!! YOU KNOW NOTHING CHUMPS!!!
  • 259 Answers
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
How do you remove the chuck from a 3/8 electric drill
Open up chuck for largest drill bit. Look inside and you will see a screw, remove the screw. Put a pair of vise grips on the stationary part of the drill chuck, which is the part of the chuck that the tightening tool goes into. The chuck is screwed onto left hand threads. Take a rubber mallet and hit the pair of vise grips clockwise sharply, to loosen chuck. You can now do what you planned on doing. GOOD LUCK FRIEND.
Feb 12, 2015 | Drills
Screw driver bit stuck in chuck of impact driver.
a tough one If can't get hold of it you may be screwed LOL
getting that rammed in the chuck is very hard to get out even if can get a grip unfortunately you can't beat it out you would do more damage And no lubricate is going to help because it was tightened down. Hope someone can help you in this otherwise may have to replace the drill
Nov 06, 2014 | Makita TD090DW 10.8V Compact Li-Ion...
Sd rotary hammer drill 110 volts bit brocken in chuck
Put some WD40 into chuck and wait a few minutes. Open the chuck as you would do when normally removing the drill while at the same smartly tapping the back of the drill.Alternatively try to grip the broken drill bit with a long nose pliers to extract it. A strong magnet might also pull the bit out.
Nov 08, 2010 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Seized chuck.
I would continue to use the rust remover/penetrating oil products, put a pair of vice grips on the chuck grip and use a hammer to tap the grips. Hopefully this will free it up. It's not very elegant and you probably have already tried similar methods but it's the best idea that I have. Also you could soak the chuck portion in penetrating oil (chuck submerged only) overnight. Good luck!
Mar 01, 2010 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Unable to grip the bit on the drill
If I understand this correctly, you are trying to have the chuck bite down on a bit. If the chuck does not tighten on the bit, your chuck is bad.
Jan 17, 2010 | Electrical Supplies
Chuck broken
Just happened to me. Oil the chuck and let it sit and soak. Very gently, put the dril into a vice to secure it. With a pair of adjustable pliers (somthing that you can get a good grip with) attempt to work the chuck free. It works but just be gentle so you dont break anything
Nov 16, 2009 | Dewalt 18 Volt Compact Drill Kit
Cannot remove drill bit from self locking chock
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
Nov 09, 2009 | Drills
Broken Makita Drill 6408k chuck
separate the housing and remove the gear assembly and chuck ....see if you can use a open end wrench on the shaft and locking pliers on the chuck body
Sep 17, 2009 | Makita 6408K 3/8" Variable Speed,...
Gripping tooth of drill detached
This is usually caused by a damaged spring between the gripping teeth. Might also be a damaged tooth. Easiest fix is replace the chuck.
Jul 11, 2009 | Drills
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Dewalt 18 Volt Compact Drill Kit Logo
4,014 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
