Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Stove Ignitor makes tik tik sound and the sparks continuously
Even though i put off my GE GAs stove top, the ignitor makes tik tik noise and ignition spark appears continuously
    Problem Solver:
  • 18 Answers
May be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
Posted on May 17, 2009
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
When I on my gas stove it's on properly bt the button gone sounds regularly like tik tik tik
Sounds like, the automatic ignitor may be stuck in the ON position... It may be continually trying to Light an already lit burner...
Raise the top, and listen and watch the Ignitor {s} to see, or hear if it is continually sending a spark... If so, and you can't see a way to fix it, then Replace it...
Nov 28, 2012 | Kitchen Ranges
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Gas oven not coming on (ignitor not glowing at all) ge jgsp28sek4ss Broiler works, stove top works, oven igniter not coming on Thanks Jim
The ignitor just needs replaced . you can find the parts using your stove model # . its two screws and a wire to replace .
Feb 05, 2011 | GE Kitchen Ranges
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove switch igniting though stove is off!
You have a bad ignitor switch. One or more of them (4) is stuck.
You need a volt/ohn meter to check the switches, one attached to each surface burner to find out which is bad.
Feb 19, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
662 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
