Question about Acer Aspire 5100 Notebook
My monitor will remain black when notebook is powered up
I turn my computer on and the notebook's monitor remains black.  The power button is lit, but the screen remains black.  I have only owned the notebook for around 40 days
  • 8451doodle Jul 01, 2008
    SF740 Compaq Monitor when turned on light will be green for about 5 seconds then goes yellow to sleep mode. Moving mouse or pushing moon key will not activate monitor. This is a old computer trying to set up for grandchild. Did turn all off and on again. Same thing, only now when button is pushed any button on keyboard it will dong. I know this means there is probably an error message. I can't receive that if I can't see monitor.
    Any thoughts or is the monitor broken. Thanks
    Donna
  • aizhen Jan 24, 2009
    I own a Acer aspire 4520 laptop. Bought it in May 2008, used only for 9 mths now. I have same problem since last month. If I off my laptop for more than 12 hours, i have this problem. While i on it, the screen remains black, but the power button is still lit on. I can still hear the sound of window and the hdd seems works fine. Only the display. I have to on & off it for more than 10 mins, in order to "see" the screen. Been sent it to acer centre for service, but problem remains. Anyone can help, please ? Thanks
    Problem Solver:
  • 30 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Posted on Jul 20, 2010
    Problem Solver:
  • 12 Answers
Your monitor may be configured for a mode that is not compatible with your display device. Start your PC in Safe mode by holding down the F8 key from a cold boot.  If your display comes up in 640x480 mode, then your problem is your display settings and can be corrected by right-clicking on your desktop, selecting PROPERTIES and then the SETTINGS tab.
If new settings do not work check your SLEEP settings in the control panel to make sure you are not "hibernating".
Failing all these, re-install the drivers for your display adapter from safe mode.
If your monitor did not come up in safe mode (remained black) enter your BIOS (CMOS) settings and ensure that your primary display is set correctly.
After these non-invasive things fail, take it back and get it covered under warranty, you have a hardware problem.
Posted on Oct 15, 2007
    Sergeant:
  • 457 Answers
Test it with another monitor if you things then maybe the LCD has a fault.  Come back here for more instructions
2 Suggested Answers
Saigua
  • 981 Answers
SOURCE: My monitor will remain black when notebook is powered up
Black uses much less power. It's a device for automation, so you really should not lavish the watts and attention on it unless it has to perform something truly novel.
If you really want to use the monitor though, you can use the function-key combination used to switch the display between internal and external displays.
Posted on Feb 22, 2008
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
The laptop needed charging. After charging, when the power button was pushed, the screen remained black. The power button is lit. What is the problem?
Sometimes when you reset the computer, that happens. disconnect the AC and count to 10. Plug back in. If that doesn't work...turn on from the power and that should automatically reset the screen.
Nov 27, 2010 | Toshiba Satellite A135-S4527 Notebook
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
The screen remains black when i turn it on. The power button turns green and blinking but the screen remains black.
try using the Fn + F?key (has a graphic of a monitor)F5 or F7 to switch the system from external monitor to the laptop ... you probably have it in presentation mode for external monitor.
Oct 14, 2009 | Acer Computers & Internet
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
http://josepino.com/?howto-repair-dell
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Feb 22, 2008 | Acer TravelMate 529ATX Notebook
My monitor will not turn on
Test it with another monitor to see if all is well and if you see things then there is a problem with the LCD.  Come back here for more instructions.
Oct 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
339 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
