Question about Whirlpool GHW9150 Duet Washer
Washer was empty,, door open...filled with water from the back,,,then on a handwash load later after load was finished,, water still in tub...had to reset it to drain/spin ... and just now,, washer's been empty for hours,, door open,, water seeping in from the back
    President:
  • 1,136 Answers
Hi, You will need to change the water inlet valve. If you will gin=ve me the model # I can get you the part # or even send you the part.
Thanks
Vic
Posted on May 15, 2009
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Water filled the tub above door seal when not running or turned on. Poured out when door opened.
most likly you sucked something into (auto) water leveler, try unplugging unit and check drain hose,also drain hose HAS TO DRAIN "UP" ATLEAST 36 INCHES, off of floor into sewer line, or it will back up into washer,thus not completely emptying last cycle, let me know if this helps,god bless
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
