Question about Acer Aspire 5100 Notebook
My monitor will not turn on
When I turn my notebook on, the monitor remains black.  I have only had the notebook for 40 days.  It showed no signs of trouble.  Yesterday, I turned on the computer and the screen remains black.  The power button will stay lit and I have to remove the battery to turn off the notebook.
  • 457 Answers
Test it with another monitor to see if all is well and if you see things then there is a problem with the LCD.  Come back here for more instructions.
Posted on Oct 15, 2007
Tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Nov 10, 2011 | Computers & Internet
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Jun 13, 2010 | HP Pavilion dv1000 Notebook
I am having trouble with the monitor showing a black screen. It will turn off in the middle of anything I am doing, quite randomly. Using windows XP Home edition. PC does not turn off, but disk light...
I would suggest to first determine that your monitor is OK. If you are using a notebook try connecting an external monitor as well and see if the same random (monitor switching off problem) happens with this monitor. If you have a desktop try connecting a different monitor.
If the same condition happens with a different monitor try updating the drivers for your video card.
Dec 29, 2009 | Microsoft Windows XP Professional
Screen goes black
This indicates the LCD inverter in the display is dead. If you have any experience with computer repair, replacing an LCD Inverter can be easy enough; However, it may not be worth it for a 15" LCD; replacement inverters can cost anywhere between $15 and $40 - a decent used 15" LCD only costs about 40 bucks these days...
Feb 13, 2009 | Balance CM2015 15" LCD Monitor
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
My toshiba
Did you try Last Known Good Configuration?
try this if ur notebook shows a little sign of life....
or else
1. unplug the laptop
2.take out the battery
3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit)
4.put battery back in
5.plug in laptop
6.try to turn it on
All the best
Have a nice day!
Jun 11, 2008 | Toshiba Satellite A60 Notebook
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
My monitor will remain black when notebook is powered up
Black uses much less power. It's a device for automation, so you really should not lavish the watts and attention on it unless it has to perform something truly novel.
If you really want to use the monitor though, you can use the function-key combination used to switch the display between internal and external displays.
Feb 22, 2008 | Acer TravelMate 529ATX Notebook
Acer Aspire 5100 Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
