Question about Maytag MAH8700AWM Neptune Front Load Washer
Maytag Neptune Frontloader MAH8700A door won't unlock
Stopped mid cycle this morning. Won't run and door won't unlock
  • brokie23 May 11, 2010
    I had a similar problem. We got the door to unlock by tilting the machine back while it was on, and had to scoop the water out with a bucket. I still haven't fixed mine but go the stupid thing to unlock.
aborcass
  • 2651 Answers
SOURCE: door won't unlock on neptune mah8700a
you can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine,
Posted on Nov 25, 2008
  • 491 Answers
SOURCE: Our maytag neptune frontloader won't start
CHECK PLUG FUSE IF OK CHECK WIRE FOR ANY BREAKS IF NONE THEN IT MAY BE THE ON /OF SWITCH IS FAULTY.
Posted on Nov 01, 2009
  • 251 Answers
SOURCE: washer going through all cycles
hi - a bit puzzled here, the drum does not turn I'm assuming, the belt has to have come off or is broken.
Take 2 bolts rear corner only, under soap dispenser (4), remove the door & front panels, door lock screws above door to get to the inside & motor. Have a look if it has come off or boken.
Posted on Jun 15, 2011
  • 86 Answers
SOURCE: Maytag heavy duty super capacity
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Posted on Jul 16, 2011
caroldon
  • 17130 Answers
SOURCE: Maytag neptune front load washer
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Now in this case the failure of the motor drive or the agitator shaft could have resulted in total failure of the spin cycle. Now remove the panel and check manually the movement fo the motor and the main drive, if the shaft is struck up or if the motor bearings/bushes are worn out. It is important to check the voltage on the motor as the absence of the voltage means that the controller has some fault - possible failure of the drive after a heavy load of the malfunction.
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Posted on Sep 09, 2011
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
How do I open the door to my front loading maytag neptune? It was in mid cycle, made a horrible sound and stopped running. Has all my clothes in it and I can't open the door.
Please check this link for tips to open the door that is jammed.
Make sure to drain the water by opening the drain valve manually.
Click on : Door lock
Feb 07, 2013 | Washing Machines
The washer was starting spin cycle. It stopped & started huming. The door won't unlock. It has water in it. unplugging hasn't changed anything.
If it has water in it it may not unlock the door, it depends on what type of door lock is fiited as it may be a pressure type. If you can get the outlet hose out and lower it below the level of the drum to drain the water that is in it then the door may open oncethe pressure is gone.
Dec 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
A string from one of the clothes got stuck in the lock mechanism and the door won't unlock
If the door fails to unlock after 11 attempts, you will see the "LO" code. If this was caused by foreign matter infiltrating the latch area try this. Open the dispenser lid and look for a plastic cord tucked away towards the front. It's the same as "weed whacker" cord. Grasp this cord firmly and pull it from right to left (away from the latch). This is the emergency cord to open the door after a latch failure. remove any debris that would hamper the operation of the latch assembly. Close the door and try going into a spin cycle to check the door lock operation.
Apr 29, 2009 | Maytag Neptune Washer
Washing Machines Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
