Question about Stoves Kitchen Ranges
Is a Range Hood a must for gas stove?
Do I have to install a RANGE HOOD with ventilation through the roof/wall, if I have a GAS STOVE in my kitchen? Is that included in Fire code? I am setting up a gas stove in my house and I live in Florida. Could you please let me know if true? I will greatly apprecate your prompt response. Thanks in advance!
  • 10,865 Answers
Hello. In order to be certain about the building code you will have to go to your town or city clerk's office and ask them directly as every town and city in the country has a specific building code. Some adopt a state or federal code, others don't. Go to your clerk's office and you will know for sure.
Posted on May 27, 2009
Does a Maytag gas stove model # CRG9700BAL have to be vented. Im replaceing a stove that quit working with this one and it has no vent, but my old one did.
Old gas stoves were designed to be vented out. the newer stoves vent out the top at the back of the top panel. You may still need to have some kind of vent in the kitchen either a ceiling vent van or a range hood. At the very least a window in the kitchen. You may want to check with the local building codes about how to vent the stove and the requirements.
Oct 01, 2014 | Maytag Kitchen Ranges
How to open the top of the stove
if its old or fairly old just lift the whole range up and you should see hinges just make sure the hinges are locked in place or slide into to place like the hood of your car. basically it opens like the hood of a car with out any latches, except some might come with a latch
Mar 12, 2012 | Hotpoint RGB745 Gas Kitchen Range
A mouse is moving white cotton like material from under the range top out the ventilation vents. how do i get the range top up? Unscrew two screws holding it in place? Also, how do i move the stove away...
just lift the whole assembly from the front it will kind of lift up like the hood of your car.(most models)as far as moving it out from the wall it should have at least a foot or 2 of give slide it straight out from the wall if it is gas be careful not to break the flexible line if electric it should have a big plug like your dryer.
Apr 25, 2011 | Whirlpool RF378 Electric Kitchen Range
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Oct 17, 2010 | Tappan TGF657 Gas Kitchen Range
We have a Kenmore gas range ( 13 years old). We
Take a spray bottle and mix up a solution of strong dish soap and water... then spray down all of the connections in the gas line...with the gas turned on and the room well ventilated.
There will be bubbles from the leaking gas where the leak is. Proabably all you will need to do is tighten the connection that is leaking...
heatman101
Apr 15, 2010 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
GE JGSP28 Range broiler problem: flame comes out when door opened
The air shutter should be completely open. A possible adjustment may be necessary towards the closed position. The orifice needle at the orifice hood may be too tight. Take a 1/2 inch open end wrench and turn the hood counterclockwise to reduce pressure on the needle. Do this with the air shutter completely open. Your flame should reduce in size. The best flame would be about 1 inch long with white tips.
Make the adjustments with the flame off. Then light it and check it. If more adjustment is necessary,turn the broiler off before adjusting.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
What space is required behind range to allow for gas hook up
If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Apr 10, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
Kitchen Ranges Logo
367 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
