Question about Kenmore 54501 Dehumidifier
I have a old Kenmore 40 dehumidifier and the pan light is on. So, I checked the pan and there is only small amount of water. I dumped it and put the pan back and the light is still on. The light goes off when I turn the dehumidifier on.
  • 11 Answers
That is normal. Check the little lever inside the bucket to see if it is moving freely.
There is a little red button that you can see inside the left front side (looking at the unit) when you remove the bucket. Press the button to see if it is sticking.
Posted on May 29, 2009
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
Not building up much water in the bucket set at 35 sometimes 50 small amount of condensation on top of machine
its low on refrigerant,this is normal after about 2-3 years use,it costs about $50-$125 to evacuate old refrigerant and seal and recharge system with new proper amount of refrigerant being it R134a or R22 freon
Aug 01, 2011 | Kenmore 54501 Dehumidifier
There is no water in the pan and it is less than a year old
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 24, 2010 | Kenmore 54701 Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Dehumidifier runs all the time when set on 35% collecting only a small amount of water in bucket.
you need to take a few covers off and check for filters and cleen the coils
Apr 08, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier has run for 24 hrs straight, no water in pan?
Have u tried cleaning the filter or replacing it? Some time if it's really dirty it may make the house smell.
Apr 06, 2010 | Kenmore 54701 Dehumidifier
I have 2 kenmore 70 pint dehumidifiers. Neither one is collecting water in the pan when running (therefore neither is running). Is there a reset button?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Feb 17, 2010 | Kenmore 54701 Dehumidifier
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
247 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
