Question about Refrigerators
Maytag Side by Side Model RSD 2200. Problem with closure of refrigerator door. Unlike the Freezer Door which closes without effort and operates as if "spring loaded" over the last few inches of travel, the refrigerator door must be pushed all the way to the full closed position. Nothing appears to be damaged or interfering with the door. can you help? Greg
  • r_gregoire May 15, 2009
    Solution sound right. Do you have any thoughts on how I might obtain correct part numbers?
    greg
    very helpful. quick and to the point. good technical writing.
    Novelist:
  • 130 Answers
 SxS refrigerators have what are called ride-ups. One half of this assembly is riveted to the door hinge the other half is screwed to the bottom of the door. It is usually best to replace both parts at the same time. Both fridge and freezer doors have this type of a ride-up.
Remove power, remove the upper hinge cover. Remove the upper hinge screws ( if the freezer door - disconnect the water line ), lift the door off the lower hinge and lay it down on the floor. The parts can be easily replaced now. See the picture below to see what the parts look like ( freezer hinge shown in the picture )....
clivck the link directly.
http://www.applianceaid.com/geride-up.html
please do rate the solution.thank you for using fixya,
Posted on May 15, 2009
  • bepositive May 15, 2009
    you can just get the parts at
    www.repairclinic.com
    or at
    www.partselect.com
    you just have to select the part name as fridge hinge.
    also local refrigerator tech will be much helpfull.
    please do rate the solution.thank you for using fixya,keep updated.thanks.
Door closure not pulling door shut
there could be several reasons the door is closing properly. first see if anything is blocking the way. is the bottom hinge raising and lowering as it opens and closes.
Oct 11, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Right side door does not close unless you push it closed with your hand
    The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
    Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on.
    Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
    Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
    Bottom freezer door opens when top door is open and then closed
    the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
    Jul 02, 2009 | Refrigerators
    Refrigerator Door Does not Close Properly
    Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
    May 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Freezer door won't seal
    its a visual thing inspect and look for somthing not right[ie..door seal torn,door warped.hinge cam broken.somthing in the way food package wise so door wont close.God bless,tom
    Jan 01, 2009 | Maytag MSD2732GR Side by Side Refrigerator
    French door refrig..right door pops open when left door is closed
    i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
    Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Kitchen aid superba side by side doors slam
    sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
    Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Right Hand door swings open too fast
    On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
    Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
    Refrigerators Logo
    105 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
