Question about Pioneer DEH-P3100 CD Player
I have a used pioneer cd deck. No sound to speakers
Have hooked up power,acc and ground. Unsure of a blue wire, so it is taped up. I have checked all 4 speaker outputs directly to two different speakers and I am not getting sound. Cd appears t be playing so I should have sound thru one of the speaker sets.
    Problem Solver:
  • 13 Answers
The blue wire would be your remote wire to hook up a amp and if you have a wire harness all you have to do is match the colors up.
Posted on May 15, 2009
I asked 3 times now!!! How do I hook up together a Pioneer tuner, power amplifier, and dual cassette deck, together then hook it up to a speaker!!!
Are we a little impatient?
It's pretty straightforward. Use one cable to connect the tape deck to the amp. Use another cable to connect the tuner to the amp. Use speaker wire to connect the amp to the speaker.
Jul 26, 2014 | Audio Players & Recorders
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Apr 10, 2011 | Pioneer DEH-P4000UB CD Player
Every time i turn off the the deh 2900 , stored radio stations are lost. how to store stations without losing them ?
this issue is caused by the deck not being hooked up to the constent from the cars battery take the deck out of the dash and get the color codes for the car and the deck and find the wire thats for the constant from the battery and hook up thoes wires
the wires are usually labeled on the deck as follows
labeled wires
red .......... ACC
yellow......+Battery
blue ........ system remote control/remote
unlabeled wires
green ...................................... speaker+
green with line ......................... speaker-
purple ..................................... speaker+
purple with line ........................ speaker-
gray ....................................... speaker+
gray with line .......................... speaker-
white ...................................... speaker+
white with line ......................... speaker-
black ..................................... Ground
orange ................................... dimmer+ (usually not used)
orange with line .......................dimmer- (usually not used)
i reccamend you to get the plug in harness that has the wireing alredy done you only have to match up the colors
i hope this helps
Aug 06, 2010 | Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA,...
My pioneer deh-p840mp powers on and flips open, and seems to function fine with the exception of no sound going to all my door speakers and the bass to my subwoofers is a far sounding muffle even as I turn...
Un hook all your speakers that the deck is powering and hook them up one by one sounds like u have a shorted speaker or wire and the unit is going into protection.The best way to chk the speakers and wires is with an ohm meter . Check each speaker wire to ground and across the speaker and see iof you have any shorts. The next step woulk be to remove the unit and have it bench tested.
Jul 30, 2010 | Pioneer DEH-P840MP CD Player
I have an after market pioneer car stereo and not sure how to hook the red,yellow and blue with the stripe, to the wire harness with orange lummination and orange dimmer negative,yellow batt. and blue i...
red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
No sound from new stereo
check the speakers in the rear deck, in the rear hatch or trunk, often the two wires that come out of the speaker touch if that happens it will short out the speaker drivers in the radio most times no permanant damage will occur. separate the wires so they do not touch,or touch the metal speker base, that may not be the problem but its a start..
Oct 16, 2009 | Hyundai Motor 1998 Accent
Trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Feb 15, 2009 | Pioneer DEH-1600 CD Player
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Jul 06, 2008 | Lanzar VIBE266 Car Audio Amplifier
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Pioneer DEH-P3100 CD Player Logo
163 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
