Question about IBM ThinkPad T42 Notebook
The AC pwoer keeps on and off (most time off) all the time, however, it still can recharge the battery
The AC power keeps on and off, however, it still charges the battery. The AC Power ICON on and off frequently, the screen keeps flashing.
  • 1 more comment
  • redbirdcard May 15, 2009
    The sreen is back forth with bright and dim, it also had beep. If I took the battery out, it does not boot by AC.
    I'm using the dock station, but same result. Will it be wrong with the AC power supplier instead of AC jack on board?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    wiggle the end of the cord where it plugs into your laptop and see if your screen goes from bright to dim or dim to bright.
    Also see wiggle the end of the cord where it plugs into your laptop and see if that changes the icon at all.
    If anything changes then that means your DC jack in your laptop has loose solder connections and they need to be resoldered.
  • 2,404 Answers
The dc jack on your motherboard is loose and needs to be resoldered then. The screen going dim to bright back and forth and not booting up just with the ac adaptor verifies the problem.
Posted on May 15, 2009
  • Ben Wabnick
    Ben Wabnick May 15, 2009
    AC jack on board is still having problems anyway regardless of the docking station. You can still try another ac adaptor if you want just to rule it out but I still feel its the jack on the motherboard that needs to be resoldered.
    Scholar:
  • 88 Answers
This is not a good sign!
If all physical connection seems fine, it could mean something is wrong on the power modules of the motherboard! Please try another power adapter to see if it's the power adaptor's fault. If not, get it into lenovo service centre for check-up, as this could damage your laptop motherboard's power modules permanently!
This happened exactly what I had on my good old ASUS laptop, I ended up replace the motherboard. Pay little money to get it serviced before you have to replace the whole motherboard!
  • Patrick Kam May 15, 2009
    Although not sure will it be a battery issue as well, but as a quick way to stop it flashing is to change the Power Settings so that the screen will not dim to save power (laptop thinks the AC power disconnected). Change both (power plugged in/unplugged) to the same level so that it remains the same brightness.
Pentax k2000 won't save time and date
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Feb 15, 2014 | Pentax Cameras
My ups is not worked properly it shut down my computer .
what is the issue mainboard or your UPS pwoer supply
the power supply has battery (1 or 2) depending on the UPS model
if the battery is over 3 years old , its time to replace it
what is the UPS model number , manufaturer ?
what si the mainboard moidel number
whats computer are you using , model number ?
have you attempte dto plug the computer directly into the (wall) AC outlet ? if its not poweing on, perhaps your computer power supply is not working and needs replacing ?
Oct 15, 2010 | Computers & Internet
Keyboard not working for ideapad s10
Usually this could be resolved by powerdraining your computer. Disconnect the battery and the adapter for two whole minutes then press the pwoer button to completely drain its power off. Try using the AC adapter power only without the battery. if it will not work still then the keyboard needs replacement. Generally a hardware failure
Mar 04, 2010 | Lenovo IdeaPad S10 - 42312BU Notebook
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
My Garmin Nuvi 255W, which comes on normally when I start the car, is not coming on. It is only about 5 months old. I keep it plugged into the lighter at all times. Do I need to worry about a battery in...
more than that! keeping it plugged into the car is damaging the SIIRF chip and battery when you start the motor. Also the unit needs to be charged properly before use in an AC charger or vIA USB The DC in the car will not fully charge the unit. In fact it also leaks power back to the battery of the car when you turn ignition off, so dropping the volatage and amps of the battery in the GPS.
ALWAYS UNPLUG BEFORE STARTING ENGINE
Always charge/recharge it prior to use in a AC or USB environment
Battery life is average 2 years unless used like you say you have. Then 3-6 months might see it collapse!
try a full and proper recharge first
Please rate our help++++Thanks for using FIXYA
Oct 09, 2009 | GPS
My inspiron 1520 will not turn on. the power light will stay lit, and the capslock will blink like 45 times, and the nothing happens
Remove the battery as well as the adapter. Then plug back the power adapter only. Try to boot up with out the battery. If it worked your laptop crashed from hibernation or stand by. If not, BIOS might be affected and needs reset.
Hope this helps.
Oct 01, 2009 | Computers & Internet
Keeps powering down immediately after turning on
I have a similar issue, it does not even power on even connected to ac adapter.
May 22, 2009 | Garmin Nuvi 680 GPS Receiver
Lense does not close
sir, ur camera lens mechanically stucked or gears problum ,this is repairable
Apr 12, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Batteries replaced but still says change them
http://www.fixya.com/support/t1100571-lumix_dmc_lz5_replace_battery
try
Sep 05, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
IBM ThinkPad T42 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
