Question about Zebra TLP 3842 Thermal Label Printer
Cuts off long lines of text
I am using Crystal Reports to print material labels. When I have a particularly long part number, it cuts it off at a certain point. At first I check to make sure the toner ribbon was on straight, and it was. I thought it could be a problem with the right side printing margins, but I'm not sure. The cutoff is not a defined line, it's more a line of deteriorated printing quality, right of which printing ceases. If anybody has any ideas, please let me know as I need to get this project underway as soon as possible. Thanks!
SOURCE: Printing Speed
what interface are you using? sounds like windows is sending the data to the printer as graphics which is much more intence then EPL hence the delay between each label.
Posted on Nov 21, 2007
ozztech
  • 285 Answers
SOURCE: possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
Posted on May 05, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Posted on Apr 28, 2009
Dymo LabelWriter 330 is cutting off part of my address labels
You should have the text box to type in. You can click on the dotted line and move the whole box up or down so the entire text will be mostly centered on the label.
Sep 07, 2017 | Dymo Office Equipment & Supplies
Set up wep
Canon iR2016J is asking Dept Id and password, So, hoe can I remove it. Please suggest me few ways to operate my machine, please.
Jul 17, 2013 | Epson LQ Office Equipment & Supplies
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
Brother ql 570 processes the print and cuts the label. However the information I want to print is not printed on the label sheet. Why is this happening?
1. is it printer other information, such as text ,photos/images or barcodes?
2. What are you trying to print.
3. Make sure the Ink color is Black.
Dec 02, 2009 | Brother QL-570 Thermal Label Printer
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
Poor Quality (black line)
Check the temperature settings. If all of the text and barcode is clear and not fuzzy, check the platten roller for low areas, cuts, or other deformity.
Dec 12, 2007 | Zebra 170XiIIIPlus Thermal Label Printer
Files not printing correctly
Try changing all the fonts to true type.
Dec 06, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Printing Speed
Mar 02, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Zebra TLP 3842 Thermal Label Printer Logo
67 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
