Question about Metabo W6-115 606111420 4 1/2" Angle Grinder
Not getting enough power?
My metabo we14-125 plus angle grinder does not seem to be getting enough power...will only turn on when not plugged into an extension and will only then run at low speed...not sure what needs to be replaced? eli
  • Anonymous May 21, 2009
    where can get metabo grinder fix or repair?
  • 31 Answers
Brushes or bearings worn out
Posted on May 15, 2009
Sparks are coming from my metabo w6-115 angle grinder where the bushing are and it seems to be grinding a bit
There are always some sparks with power tools from the brushes.
You should remove the brushes for inspection to check wear.
Be sure to reinstall in the same direction.
Jul 16, 2011 | Metabo 06204 4 1/2" 900W Ang Grinder
Need to put metabo w14-150 ergo back together
Hello. There are actually a few different grinders (style of) with this product number. Here is the link to the Metabo home site. They have downloads available of parts lists and specifications that should be of assistance to you. Should that fail, use their contact information, and have them supply the required information. If this helps, please rate this answer a four-thumbs up - Thank You.
http://www.metabo.us/
Apr 02, 2011 | Metabo W14 150 ErgoD Angle Grinder
Dear Sir, We have few Metabo grinder I have some doubt about Dead man switch can you explain me what is the function of dead man switch. Regards Nitin
Hello, a dead man switch functions in this manner. As long as you hold the switch down the grinder functions, and as you know when you release it the grinder stops. This is a good safety feature in that if you drop the grinder of lose control of it, if the grinder stays running it could cause a lot of damage to material or your body. The switch can seem to be a pain when having to hold it down all the time, but it is a safety feature that can actually save your life in the case of you losing control of the unit.
Mar 13, 2011 | Metabo W10 150Quick Angle Grinder W10 150...
I own a metabo 9-125 quick but can't don't know how to place the blade
On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Magnetic brush size
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Sep 13, 2009 | Metabo WE14-150 Quick Angle Grinder
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Metabo W6-115 606111420 4 1/2" Angle Grinder Logo
598 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
