Question about Northstar Pressure Washer 3000 PSI
Looking for a manual for northstar pressure washer 157816A
  • Anonymous Mar 30, 2014
    Need a manual for northstar pressure washer
  • 17 Answers
Please use this link for more information for the manual:
http://www.northerntool.com/catalog/buyersguides/pressurewashers/
Posted on May 14, 2009
My northstar pressure washer has no pressure
PDF]Owner's Manual - Northern Tool + Equipment
https://www.northerntool.com/.../1577544.p...
Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
Sep 21, 2015 | Northstar Garden
Northstar pressure washer manual 157170
look on there sitefor manual.
Aug 12, 2012 | Northstar Garden
Looking for an electric starter for Northstar Model 157892A
Is this the engine model number or the machine model number? Is the motor already set-up with an electric start or is it something you are looking to add?
Oct 30, 2010 | Northstar Pressure Washer 3000 PSI
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
I have a northstar 2800psi 2.5gpm washer that doesn't pick up the cleaning soluion, is there an adjustment to make it **** the fluid out more?
There isn't an adjustment for pulling the cleaning solution out faster or slower. It's an automatic function, based on the size of the power washer (meaning it ****s at different rates for different sized washers). Here's a link to the manual for more information:
http://www.northerntool.com/downloads/manuals/1577543.pdf
Hope this helps!
Aug 30, 2010 | Northstar Pressure Washer 2800 PSI
I can't find my manual and no longer remember what the fuel mixture is for my workforce 163cc power washer. Can you help me? Thanks much.
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
Jul 17, 2010 | Northstar Pressure Washer 3000 PSI
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Sep 03, 2009 | Northstar Pressure Washer 3000 PSI
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Northstar Pressure Washer 3000 PSI Logo
2,120 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
