Question about Whirlpool LSQ9610L Top Load Washer
Washer will fill agaitate but won't drain or spin
I have a whirlpool washer and it agaitates but it won't drain the water and it won't spin, i looked at the pump nothing lodged, checked the coupler nothing wrong there, i was told it was the safety switch and to jump the wires so i took the 2 grey power wires and spliced them together and now i get nothing just a eeeeeerrrrrrrrrr sound like something is stuck i have no clue what this could be i think possible the brake or the clutch nothing is black or burn smelling everything is clean can u help.
aggrevated in pa
  • 5,911 Answers
Have you checked the lid switch? A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know. NOTE: I don't know of any "safety switch" on the washer. You can, however, by-pass the lid switch to get it to work temporarily. It is by-passed by jumpering the plug in the console - not splicing any wires. I would not recommend by-passing any safety features, though. You may cause damage to the machine and/or anyone that attempts to use it.
Posted on May 14, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Ok, this washer has been loyal and a trooper up intil two days ago, I went to start a load of laundry and, it fills with water, but when it is time to agaitate it starts making grinding noises, and wont...
This sounds like the transmission is having a problem and can be a very costly repair. If you haven't money to repair it, as it seems you may not, you can try free cycle dot org and see if any one is willing to give you a used machine they aren't using.
Aug 29, 2011 | Washing Machines
How does the soak cycle work. Does it start at the end of the wash cycle, or does it drain the soap and soak in clear water
typically on the soak cycle it will fill with water..pause and soak then at the designated time it will advance into the regular agaitate/spin cycle
Aug 26, 2011 | Fisher and Paykel GWL11 Top Load Washer
Have whirlpool LSR7233B top load washer. It fills and agaites but will not drain all the way and spins slowly on slowly on spin cycle
THE BELT THAT DRIVES THE DRUM MIGHT BE WORN, THE BELT IS NOT UNDER A LOT OF STRAIN WHEN WASHING AND MAY WORK FINE BUT WHEN IT GOES INTO THE SPIN CYCLE THE WEIGHT OF THE CLOTHES AND THE WATER WILL CAUSE THE BELT TO SLIP . I WOULD START THERE FIRST
Aug 23, 2009 | Whirlpool Washing Machines
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSQ9610L Top Load Washer Logo
275 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
