Question about Dryers
Dryer keeps tripping breaker
cut dryer on it runs 5 seconds upto 5minutes then trips breaker.it worked fine for first week
  • smaag May 11, 2010
    How old is the dryer? Model? Usually tripping the breaker can be 1. the heater coil(s) are worn out and shorting to the case of the unit causing the breaker to trip.
    2. the breaker may be bad and tripping prematurely.
    You can test for a short if you have a volt/ohm meter.
    Problem Solver:
  • 6 Answers
THE BREAKER IS GOING BAD REPLASE IT OR THE BREAKER IS TO WEEK FORE IT TRY ANATHER PLUG
Posted on May 15, 2009
What part need to replace LG DLGX5171V keep getting power Trip or stop working
Check wires going to motor. Must be a short there.
Aug 16, 2017 | LG Dryers
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
Sep 04, 2012 | LG DLG3788W Gas Dryer
Ac works 5minutes trips breaker fan works on fan onley
replace capacitors, tighten electrical connections at panel.
Sep 03, 2012 | Dometic Rooftop RV Air Conditioner
I have kenmore washer/dryer combo model 970-C98802-00. Been using for years until last week it starts tripping the breaker when using the dryer. It does not trip the breaker if no heat. It only trips the...
since it runs on air you have a grounded heater coil. Either the heater has sagged or broken and is touching the frame, here is a website that will assist you, Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 31, 2011 | Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
We recently had a power cut since then our spa has not gone it keeps tripping circut breaker, have tried powertools in socket and they work fine, it does run for about 5 secs b4 tripping? thanks
If it ran fine on the breaker before then you probably need to buy and install a new breaker. The don't cost much so you should try that. Good luck!
Jun 27, 2010 | Pool & Spa
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer keeps tripping circuit breaker. neither new.
This is common, I see it about 4 or 5 times a week. Your heating element is broken. The broken end of the element is touching the element housing. This is easy to replace after you remove the back of the dryer.
Please rate this solution
Sep 01, 2009 | Whirlpool Dryers
Dryers Logo
172 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
