Question about Sony KP-57WV700 57" Rear Projection HDTV
Can't turn blue down, it overrides the other colours.
Replaced blue tube and can't turn down the blue, it is overriding the other colours
  • Sony Master
  • 3,866 Answers
Conveergence is a huge problem here and if it overides the support your trying to give it it will be manually steered so it does not overide other colors.. You can do it carefully or can have a repair guy do it in about 30 mins or less good luck to you..
Posted on May 14, 2009
How to unlock weige digital control TV .
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Feb 29, 2016 | Televison & Video
Override thermostat temperature setting on ge rak1481d
To override the temperature limits, simply remove the thermostat cover, and then carefully replace it again, making sure the pins line up correctly. That's it! You can now set the thermostat as low as 60° and turn fan to "On."
Mar 16, 2013 | GE RAK147D1
Neptune door lock override
You can't override the door lock It's a safety feature. You can bypass it by connecting the wires that go to the switch but please don't! It means the door can be opened while the drum is still spinring and children can be severely injured. You may also open the door accidentally with water in the tub. If you think there is a fault with the door lock, first make sure it's not just a blocked air tube, but replace it rather than try to override it.
May 15, 2012 | Washing Machines
I have a APEX television. My kids were playing with the remote, now i have a blue screen with a red key sign on it, i can't do nothing with the television now. what do i do?
Hello
Your Apex TV ahs been locked. It can be unlocked by the folloing method.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Jul 06, 2011 | Televison & Video
Hello I am seeing a blue screen and a lock on the bottom left corner. I am unable to change channels or input. Please advise.
Hello
Your Apex Tv is locked. You must unlock it and reset all the V-chip settings once more. To unlock it do the following.
OK.
Jan 11, 2011 | Apex Digital Televison & Video
Apex tv model gt2711s blue screen with a lock icon at bottom left of screen. Tried solutions mentioned. Cant get to menu. I bought a replacement remote Model RCU-200 Turns the set on and off. Locks and...
Hello
OK
Happy New Year
Dec 30, 2010 | Apex Digital AT2702 27" TV
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Printing problem
The 2600n turns all 4 inks no matter if you print in mono or colour. Each turn adds an extra page count to your toners usage, so if the toners are good for 2500 pages even if you print 2500 mono pages your 3 colours will run out also.
You CAN turn this feature off and the printer will continue to print after it has 'run' out of toner, we do this at work and have gotten an extra 1000 prints (and going) out of the cartridges.
Cartridge Out Override can only be enabled from the printer's control panel menu.
1. From the main menu, press (RIGHT ARROW) to System setup and press (SELECT).
2. Press (RIGHT ARROW) to Print quality and press (SELECT).
3. Press (RIGHT ARROW) to Replace supplies and press (SELECT).
4. Press (RIGHT ARROW) to Override out and press (SELECT).
5. Press (SELECT).
If Stop at out is selected, the printer will stop printing when a cartridge reaches the recommended replacement point. If Override out is selected, the printer will continue printing when a cartridge reaches the recommended replacement point. The factory default setting is Stop at out.
Mar 21, 2008 | HP Color LaserJet 2600n Printer
HELP to unlocked tv
You will need the original remote control to unlock this set. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Mar 07, 2008 | Apex Digital AT2002S 20" TV
Sony KP-57WV700 57" Rear Projection HDTV Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
