Question about Gateway Laptop T3200
I have a gateway 7324gz with a intel inside pentium 4. The power connector burnt out and had it replace. Now it powers up, but there is still nothing on the screen. Could this be the motherboard and it so what motherboard do I need to buy.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try reseating the memory sticks one at a time in each slot one at a time and see if that does the trick.
    Scholar:
  • 70 Answers
It could possibly be the motherboard, but there's a couple of steps you should try first. First and foremost, unplug the laptop, and remove the battery, then press and hold the power button on the laptop down for about 15-20 seconds. Then plug the power back in (leave the battery removed) and try again.
If you still have no video, then power off the laptop once more, remove the power, go underneath the laptop, and using a #0 or #1 philips jewellers screwdriver, remove the plastic cover that holds the RAM, and remove both modules. With them removed, once more, plug the power back in and turn the laptop on. If the computer begins emitting a series of loud beeps (to denote a "No RAM" POST error), then it may very well be one of the sticks of RAM that are at fault, in which case you'll have to reinsert each RAM module, one by one, powering the unit on each time a stick is inserted, to see if you can isolate as to which RAM stick is the faulty one.
However, if you don't get the beep, or swapping sticks of RAM doesn't seem to help resolve the issue, then you do have an issue with the motherboard, in which case it would have to be replaced. The motherboard for this model of gateway is simply called "Gateway notebook Motherboard". The part # from gateway's website is 102156 (you may have to consult an authorized service center to have the part special-ordered in for you)
Posted on May 15, 2009
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I've been trying for days to get my computer to turn on. I had it plugged in when the power went out a while back, I've asked on Yahoo! Answers and was told to get a new power supply, I did. Now I've...
try removing everything you do not need from the motherboard - all USB connectors, front panel connectors (except power switch), ide and sata cables, PCI boards, sound connectors, just leave the essentials for the motherboard to function (also check for lid switch). Make sure you have 12v connected if applicable.
If it still does not power up with a new PSU it is likely that the motherboard is faulty.
Mar 03, 2011 | Gateway 834GM Intel Pentium 4 3.0GHz / 1GB...
Gateway 550GR Still Not Booting Up
Have you tried a different power-supply?
A power-supply must emit a few different voltages; if it fails to output one of those voltages, the fans still may spin, and the CD-drive-tray may still open, but the motherboard may not be getting the correct voltages.
Disconnect the AC power, and then open the case. Look at the capacitors (those black/silver cylinders with an X in their silver-coloured top).
Any capacitor that is bulging, i.e., does NOT have a perfectly-flat top, is leaking. Any capacitor that seems to have rusty-brown "sand" on top also is leaking. Either way, it's time to replace the motherboard.
Jul 03, 2010 | Gateway 550GR PC Desktop
Changed power supply, everything is connected and
well you may have a bad video card or maybe even a monitor have you tried another monitor? if so, then you can purchase graphics cards at most electronics stores!
Dec 22, 2009 | Gateway GT5012 PC Desktop
Intel D945GCLF - No post, No video Signal
Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
Sep 22, 2009 | Intel D945GCLF Motherboard
Turned off PC one night working fine. Next time try to use, PC wont boot. No video display, no bios, no posts, nothing. Gateway Desktop GT 5464 w/ integrated video, Intel E2140 Processor, Intel 945GC Mobo....
Have you tried booting it from yor CD drive with bootable software?
Any led flashing anywhere in the computer?
If not, we are talking about energy problem. Try fitting the energy cord firmly, try connecting the battery charger in a different power outlet.
Aug 26, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I have a gateway mvn 350 laptop with Intel Pentium 4 CPU 2,66Ghz/512/533 SL77M Malay. Now my question is, since sl77m is not available easily, is it compatible with other chips with the same 478 pin...
I purchased a replacement A/C power adapter for my gateway mvn 350 laptop. It hissed and would not power my computer. Today I have received a replacement;again the same problem occured. My current adapter is very worn and I will not be able to use it soon. Is the problem the adapter or the recepticle on the computer?
Jul 30, 2009 | Toshiba Mobile Pentium 4, 2.66 GHz (SL77M)
No display on screen and solid amber light on pcs' power button
Well hate to say it but that sort of problem results from a faulty motherboard or processor so if you say that you have changed the motherboard then you problem lies with you processor chip.
Jun 06, 2008 | Intel D865GBF Motherboard
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Gateway Laptop T3200 Logo
378 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
