Question about Hitachi Performa CP-RS55 Multimedia Projector
Cuts out After running for some time it cuts out. Tried new bulb but the problem persists. doersn't do it when it's being used outside! Is there a themal cut out? If so where would I find it and how would I repair it?
  • 563 Answers
Hi Radiodude
Firstly check if all your fans are running. If it only does this indoors it means that the unit is not getting enough ventilation.
Posted on Mar 26, 2008
Cuts out after start up
clean the carb and tank etc !
Mar 30, 2014 | Honda NSR 125 Motorcycles
Freezer running continually and not cutting in and out .Alarm light is onlo
you have to replace your themal control switch before you burn out the compressor
Sep 27, 2010 | Freezers
LEFT BLINKER RUNNING AT HIGH BLINK RATE
Make sure bulb replaced is the required 2 way or 1 way. If you're sure you put in the right bulb type (1 way or 2 way) 6 or 12 volt.. bulb model marked on side for replacement (Check carefully). Assuming its the right bulb type and still blinks fast, you will have to replace the socket. Sockets do get corroded and worn. Disconnect the battery, cut positive then cut negative. Wire up new socket same way using wire connectors. Tape up connections after.
Should then work.
Make sure before you do this you have the right bulbs in all sockets (front and rear) and that all lights work 1st. One failing light front rear same side can cause this problem.
Go to a scapper to get a socket.. just cut it off a wreck... take a couple of them. There cheap.
Good luck
Mar 24, 2009 | 2003 Pontiac Montana
Flame will cut off in 30 second
check the loose blower wheel and lint in the filter housing phenom associated with these dryers. The operator coils will get hot and quit and cool down after several hours and work again making it imposible to pinpoint a solution. Replace those coils. $20 bucks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Ruud heat pump question
Does the air handler take a minute or two to start, this would be normal so that it doesn't blow cool air into the house before the unit is warmed up. If not could be the fan relay is weak and needs replacing. As far as the outside unit it sounds like you need to check the refrigerant. In cooling they are 70/150 psi. This should be checked in cooling mode, once you turn it to heating mode the pressures switch bring heat inside the house instead of out. I hope this helps.
Oct 23, 2008 | Ruud Heating & Cooling
3.5 TON GSH14 GOODMAN WITH TXV
is it a heat pump? or the furnace cutting out?
Jun 03, 2008 | Goodman GMS90703BXA Heater
Prints with a line cutting through
change head cable ,as it is damaged- broken
May 26, 2006 | Epson LX-300 Matrix Printer
Hitachi Performa CP-RS55 Multimedia Projector Logo
35 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
