Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Leaking water from pump motor
I have found my leak from the pump motor from the broken impellar shaft seal. Is there any place that would have the seal?
  • Frigidaire Master
  • 528 Answers
Sears part :)
Posted on Jan 01, 2010
My new pump leaks around seal plate
Leaking wet ends are a result of a bad shaft seal.Check to make sure it is installed properly or install a new shaft seal to prevent more leakage.If the motor runs and it will draw the leaking water into the motor and ruin your motor.Change the shaft seal as soon as you are able to prevent further motor problems.
Rod
US Parts Center
888-521-6813
Mar 02, 2013 | Pool & Spa
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Water is leaking at the bolts. It is only 2 years old. Could it be the gasket?
might be a broken seal plate, or a shaft seal.. see picture on how to remove your pump and search you area for your local pool pump motor repair guy.. this might be a 20.00 fix .. shaft seal,o-ring or gasket ?
Jun 14, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
The Pump overheated
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
May 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Water pump leak how to remove to change seal or crack from freezing
Remove two screws at the front bottom ends of the control panel and tilt it back to expose two large brass color clips that hold the cabinet in place. Disconnect the lid switch wiring at the plug. Remove the clips and lift/slide the cabinet forward to remove it. The water pump is at the bottom of the "motor stack" and slips onto the motor shaft. You should be able to see water drip marks from the shaft bearing if the pump is leaking. Remove the inlet and outlet hoses before trying to remove the pump. The pump is held in place by two spring clips.
Jan 18, 2010 | Kenmore Washing Machines
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
155 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
