Question about Canon CanoScan 9950F Flatbed Scanner
New computer... CanoScan 9950F Toolbox says it is "Unable to select TWAIN source." Can not find the CD-Rom that came with the scanner.
  • miguelsenior May 15, 2009
    I downloaded Windows Vista, (don't know what 64x is,) when I click SCAN in CanoScan Toolbox I first get a Select Source Box with only one source listed - "WIA-Cano Scan 9950F 1.0 (32-32)"
    When I click that I get abox that says "Unable to select TWAIN source."
  • smaag May 11, 2010
    Have you downloaded the drivers for your new operating system? You should be able to find them here.
    http://www.usa.canon.com/consumer/contro...
SOURCE: Lock Switch and IF cable
Mine was doing the same thing. When I get on the program, before I click "acquire" to preview and scan, I click OFF the toolbox and then everything seems to be okay and I can go ahead and scan.
Posted on Dec 29, 2007
  • 111 Answers
SOURCE: canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
Posted on May 19, 2008
SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Posted on Sep 30, 2008
n25an
  • 622 Answers
SOURCE: CanoScan N650U TWAIN problem
ok two possibilities...
1. try this quick faq
2. try downloading vuescan... it works but for it to work perfectly you need to register it... otherwise it shows dollar signs over everything...
Posted on Dec 21, 2009
  • 13433 Answers
SOURCE: Unable to set TWAIN capabilities. When I try to
Unfortunately solving the problem might come down to reinstalling windows to the computer entirely. I think it would be best for you to keep using the program where it works.
I'dd suggest that you back up all your files etc, to a external hard drive, and then use the recovery disc that came with your computer to reinstall it to the state it used to be when purchased. or use a windows installation cd.
Then install the scanner back and it should work fine.
Posted on Dec 07, 2010
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Install CanoScan 9950F Driver
I found the answer to the 9950F VISTA driver - I went onto Canon's site and downloaded the VISTA driver - AND - the toolbox. Then a reboot and this time Vista recognised the 9950F.
Sep 15, 2008 | Canon CanoScan 9950F Flatbed Scanner
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error message
Hi toolpusher
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
May 22, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon scanner
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Nov 27, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan 9950F Flatbed Scanner Logo
1,025 people viewed this question
old marine
old marine
