Question about Dewalt D24000S Wet Saw With Stand
Dewalt ds2400 wet saw will through in line breaker not start
When i try starting saw the in line breaker triggers , reset switch but saw still thruoghs breaker when trying to restart
  • 29 Answers
Sounds like the breakers working to good,i would by pass the reset switch,most likely that switch is bad anyways,we always plug our saws into a outlet box that has a breaker in it ,you know those reset switches are stupid, by pass the reset switch like it wasnt even there,and if that works i would replace the whole cord with a new 1,and buy a 5 dollar junction box that has a breaker in it,i dont know if there is a seperate plug on that saw where u plug the water pump into, if there is i would check that plug first before you bypass the switch.good luck chad
Posted on May 31, 2009
DeWalt 744 table saw stopped. Power to saw is ok. Checked breaker and cord. Also pushed red reset button on saw switch. No change
In your service Manuel you'll find the location of the safety triggers. It's highly possible one of them has a bad connection. Very briefly and carefully jump each one till you see a change to eliminate them one by one.
Sep 20, 2017 | Dewalt Saws
Coord is fine tried many differant outlets, bu as soon as i plug it in the circuit braker trips.Any help about where the short is?
65 AMPS? That's drawing a LOT of power.
Is it tripping the breaker even before you pull the trigger?
If yes, I would use a continuity meter to start checking the various components. In particular, see if the switch is stuck in the ON position.
Unless you are experienced in tracking and performing electrical maintenance problem solving, this may be a situation best left to a repair shop.
Cheers
Mar 13, 2016 | Dewalt DW303 Heavy Duty 65 Amp...
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
Does my 20" DeWalt scroll saw have a reset switch?
check if there is a reset on the motor..usually push to reset.
Jul 29, 2014 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
What is the security lock on a Dewalt 24v reciprocating saw? Does it affect the use of it? I want to purchase one but the security lock doesn't work. Thanks for your help.
The trigger lock on a recip saw is a safety device that is there so the trigger switch will not work unless the lock is pressed first. If the lock doesn't work the saw will still work properly, it just isn't as safe. Anything that touches the trigger switch, from accidental contact by yourself or things you're working on to little children, can make the saw start up.
Mar 18, 2011 | Garden
Dewalt dw705 miter trigger won't pull/depress
DeWALT DW705 TYPE 8 12 Inch Miter Saw Parts Sounds like a bad switch, Since you don't have any money it go ahead a replce it. Good Luck
Sep 07, 2017 | Dewalt Saws
How to reset a 740 power shop radial arm saw. Saw stopped during a cut. Breaker is good. Power source is good. Can find the reset button.
Hi Welby:
My saw is not a DeWalt, but the procedure should be similar.
First, WORK SAFE! UNPLUG THE SAW.
Now you can explore without the prospect of having it bite you.
Here are the things I would do:
1) Set the On/Off switch to OFF
2) Have a look at the motor. There should be RED (typical) reset button. When you find it give it a good solid push.
3) Check to make sure the On/Off switch is still OFF.
4) Plug in the saw.
5) Try turning it on.
If it does not work, I would unplug it and use a continuity meter to start checking the various components, especially the On/Off switch. If it has failed and you can't get a replacement you could
do as I have with an old Craftsman. It is 110 or 220, and has only been used on 110. Half of the switch terminals had arced over 40 years of use, so I just re-wired the switch to use the other terminals but still be 110. .
Feb 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt D24000S Wet Saw With Stand Logo
482 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
