Question about Canon PowerShot A540 Digital Camera
Can not change the number of images that can be taken
How do you change the number of images that can be taken in order to make pictures show clearer. I guess that would be changing the megapixal or something. I do not know. It is a canon powershot a540 series.
  • 1,305 Answers
Ok, this is a very easy procedure..
While in picture taking mode, press the set button and it will activate the controls to choose the image resolution. If you select a higher image size or number, it will improve your quality of picture as the number of the resolution you choose gets higher. Simply use the side scroll and the up/down scroll on the back... that will do it for you!
Posted on May 14, 2009
My cannon power shotA4000IS suddenly stop showing/focused pictures the scree show a blurred image of photo taken?
If you are convinced you did not switch the camera to manual settings, and the blur stays, please contact the nearest Canon certified service centre close to you. But before check the settings on the camera and start putting it on automatic.
Sep 11, 2014 | Cameras
My DMC-TZ3 always stores images in haphazard order, not the exact order in which they were taken. Why? And how can I make it store images in chronological order please?
This is from the manual: "File numbers are reset when new folders are created." "New folders are created in the following cases: 1. When pictures are taken to folders containing files numbered 999. 2. When using cards already containing the same folder number (including pictures taken other cameras, etc.) 3. When recording after performing a 'NO. RESET' (found in the setup menu).
Sep 18, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Blurry enlargements
I suggest altering the settings a little and if that doesn't work try using a different software to enlarge images. Such as windows photo gallery. That's not too good for enlarging just good for keeping the quality up if that isn't good enough try using a free trial of photo shop.
Hope I helped Dr Red
Apr 05, 2010 | Sanyo Xacti VPC-CG9 Digital Camera
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
images
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
manager
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
versa.
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
Bluetooth®.
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
order.
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
status.
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Apr 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures won't show on screen
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
Jan 21, 2009 | Nikon D70s Digital Camera
Nikon D-80.
See the Manual: showing the picture actually shot is an option in the camera setting.
May 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
Nov 19, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Copying photos to CD in the order they were taken, by date.
The only way to do this is to right click on each image and rename it to the day sequence you wish or better still simply number the with a 3 digit sequence -001 002 003 etc., Once you have got the hang of it it is surprising how quick you can get So you retain the original number and put the sequence number in front like this 001-4/23 002-4/23 etc., for that day then 001-24/4 0024/24 and so on You then have them in numerical order in daily batches
May 18, 2007 | Olympus EVOLT E-500 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Canon PowerShot A540 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
