Question about Thermos Grill2Go Fire+Ice
How do I let down the grill after use? - Thermos Grill2Go Fire+Ice
  • 10,865 Answers
Http://www.charbroil.com/Consumer/ConsumerCreateCase.aspx
go to this link, fill in the info requested and ask your question, an expert from the company, charbroil will answer u on email. Enjoy your grill.
Posted on May 15, 2009
Our Weber Q grill CAUGHT ON FIRE TONIGHT !! RIDICULOUS ! It almost burned our apartment down - WTF ????
Not exactly sure what your question is, but there are a several reasons as to how and why a gas grill will catch on fire. And almost all the reasons, boil down to one thing - a lack of proper routine maintenance (i.e. Regular and frequent cleaning of the grill, checking the grill hose and regulator for leaks, keeping the grill a minimum of 6' from exterior walls when in use and turning OFF the gas tank when not in use).
I'm truly sorry, you had such a frightening experience, but in 86% of the cases, operator error is the cause.
Apr 17, 2011 | Weber Q Grill
How do i work the grill?
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
Bought this used in good shape cant get the grll to go down and looking for manual
As far as how to lower: Step (and hold down) the foot pedal, while holding the pedal down, push the grill down evenly on both sides at the same time. Let off the pedal when the grill is all the way down. I have two of these grills and love them. One will not stay down and I am working through that now. I'll post if I figure out the adjustment. Happy grilling, Don
Apr 23, 2010 | Thermos Grill2Go Fire+Ice
Just bought a grill to go at a yard sale . Can you cook with the lid down or does it have to be up when cooking?
Yes you can cook with it down. It will get hotter being down so you may have to adjust the heat lower.
Jul 11, 2009 | Thermos Grill2Go Gas Grill 4656110
How do I put grill down when finished using?
You have to step down on the petal in the back of the grill, place hands on each side of the top of the grill and press down hard..took us awhile to figure this out. We just did not push down hard enough. Hope this helps.
Jun 10, 2009 | Thermos Grill2Go Fire+Ice
Grill removal
the lower clips are pushed down with a long screw driver from the front , when the grill is removed the clips need to be removed from the vehicle and put in the grill then push the grill in
Apr 18, 2009 | Mitsubishi Pickup Cars & Trucks
Hard to iqnite Baby Q grill
Do you leave the lid down when you ignite the unit? I had this problem with another brand of grill but when I leave the lid down and ignite the grill, it works perfectly.
That said, call Weber Customer Service and share the problem with them. I've never found a better customer service department than at Weber.
PFSmith
Nov 22, 2008 | Weber Baby Q Grill
Thermos Fire and Ice Grill 2 Go
Push down on the foot pedal in front of unit.
Jul 15, 2008 | Weber Gas Go-Anywhere Grill
Thermos Grill2Go Fire+Ice Logo
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
