Question about HP Photosmart C7280 Laser Printer
All in one Photosmart c7280 will not recognize mirror feature on photographs. What can I do?
I changed from XP to Vista and my All-in-one Photosmart c7280 will not recognize mirror image feature. What can I do?
  • bilbojf May 15, 2009
    We have tried this twice. Once downloading and then deleting printer, deleting all things that might be causing it, and then adding printer back and trying again. Nothing is working at the moment. Maybe it is a bad printer. I am getting very annoyed because this printer is only just a year old and I have had so much trouble with extended warranties that I said no when asked. Hope something will develop to help. Thanks. Bilbo
  • 696 Answers
Have you tried installing the newest version of the vista software for your printer yet?
if not first go to this link and download and install it:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3204785&lang=en
Use the second download, the full suite. Then try again.
If it doesn't work comment back here and I will pull up and image for you of where the feature should be.
Hope this helps FixYa,
Chris
Posted on May 15, 2009
  • Chris
    Chris May 15, 2009
    Ok, I understand. I have the same line of printer I bought recently to replace one that lasted about 5 1/2 years. I like em but in fact when I set mine up on the network all the 2000/vista pc's and the Mac had no problem talking to it but the 2 XP machines actually defaulted into Mirror Mode. Of course the first thing we printed was the wifes 28 page tax return, almost sent it that way too.
    Anyway sounds like you have aa good idea what you're doing but I'm going to pop those instructions up anyway, give them a quick look and compare with your printer settings. See if you have the Mirroring turned on for sure. If it's on and the printer won't mirror it could be a failing in the computer or a shortage of RAM in either the printer or your PC as you try tp process the print job.
    Ok, for more redundancy, open Start menu, then Control panel, make sure it is in clasic view and open the piinters folder.
    Identify your HP printer then Right-Click the icon and select properties
    Now Click the Printing Preferences Button
    select the advanced tab and verify if the mirror setting is On/Off mine is off in the picture
    Ok, if it is on, and doesn't work it is likely a problem of not enough memory, if that is the case you can test this by printing a single line of text from notepad in mirror mode, if it works you need more memory for the printer, if it doesn't work there may be an issue with the driver for you model on vista. If that's the case try emailing hp support to tell them the issue, would be helpful to include a link to this webpage forum so they can see what has already been tried.
    Hope this helps,
    Chris
I installed a vista driver for my allinone HP photosmart c7280 but the operating system does not recognize my printer. The software has installed though. Is there anything I can do to get Vista to...
Just make sure service "printer spooler" is running. To open windows Vista service under 'Run' type 'services.msc', then have a look that service is running or not. You can just simply right click to start it.
Aug 05, 2011 | HP Photosmart C7280 Printer
Where is my mirror image feature?
Looking at the User Guide, it appears that the Mirror Image option may require you to select "Iron-on transfer" as the paper type (see p. 96 in chapter 7):
To reverse an image for iron-on transfers
1.
On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Printer Features area, select On from the Mirror Image drop-down list.
9. Click OK, and then click Print or OK in the Print dialog box.
Jun 25, 2010 | HP Photosmart C7280 Laser Printer
Printing in mirror image
If you look in your manual, it should tell you where the option is. If you can't find your manual, there should be one up online. I did a quick search to find where that option may be, and this is what I found:
In the Printer Features area, select On from the Mirror Image drop-down list for it to appear as an available option
Like I said, you may need to look in your manual to find out for sure.
Hope this helps! :)
May 03, 2010 | HP Photosmart C7280 Laser Printer
How can I get Windows 7 to recognize my HP Photosmart C7280 as a FAX device?
Download the Vista drivers/software and try that. Those drivers allow for all functions.
Try this link for Windows 7 drivers:
http://h41112.www4.hp.com/promo/win7web/printer-support/us/en/photosmart.html
Mar 11, 2010 | HP Photosmart C3180 All-In-One InkJet...
It is printing an extra page in between every page
I got this answer from another website but it worked for me!!
are your computers running windows XP or Vista? because in Vista, if it uses the pre-installed drivers that come with the OS, then it prints blank sheets between the printed sheets. if you install the driver from the CD directly, then it has resolved the issue a lot of times for me.
so to the properties of the printer, and go to the Advanced Tab, and click in New Driver. and in teh wizard, select HP Photosmart 'C7200' and not Photosmart '7200' (considering it is the Photosmart C7280). that should work.
Feb 20, 2010 | HP Photosmart C7280 Printer
I am trying to set up a new HP Photosmart C7280 All in one. I get an error message: Cannot read source disc. How do I finish setting up this printer?
>well it could be that your disc is damage. what i can suggest to you is go to www.hp.com
>select support and drives tab
>select download drivers
>type in your rinters name c7280
>select your operating system
>download full feature drivers and save it in your desktop
>install the drivers
>if you dont have internet what you can do is use generic driver
>go to printer folders if you are using windows xp or vista
>select adda printer
>select add local printer and select usb port on connection type
>select hp as manufacturer
>select deskjet 990c as printer
>this is a generic driver and will work for all hp printer
Sep 25, 2009 | HP Office Equipment & Supplies
Trying to print an photographic e-mail,
Unplug printer, uninstall HP printer software, restart, reinstall software, when it asks-plug back in and turn printer back on. If it will print other pictures, the problem may be the location of what you are trying to print(try saving as jpg to desktop and try from there). Firewall and anti-virus programs can cause problems too, you can check for known compatibility issues at hp support.
Usually the un & re install will fix it.
Sep 11, 2009 | HP Photosmart C7280 Laser Printer
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Apr 22, 2009 | HP Photosmart C7280 Laser Printer
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7280 Laser Printer Logo
261 people viewed this question
Seeker5211
Seeker5211
