Question about GE Ovens
How connected frigidare electric double oven model fleb27t9fc - i need to know (1) is it supplied with a wire to connect it to the home supply wire via wire nuts, or (2) does it need a 50 amp corded plug to connect to the oven and then a receptacle to plug in the cord
  • mtcef May 15, 2009
    for my oven, i need to know if it is delivered with a "pigtail" for hard wiring, or with a need to buy a cord/plug and a receptacle to plug it into. the suggestion to use "burndy's. . . ie split bolts was good, if it is delivered with a pigtail please reply to if it does or does not have a pigtail
    President:
  • 1,865 Answers
You can connect it either way. However I would recommend either split-bolt connectors or ring lugs w/ bolt and nuts rather than wire nuts, if you choose to hard wire it.
Posted on May 15, 2009
  • buffalonyman
    buffalonyman May 18, 2009
    It may come with pigtail or terminal block....either way, its your choice how you connect it
I just tried plugging my new oven in (model number jrp24) and my GFI flips. The oven is off and the wires are connected properly. I live in a country that requires 220v, even though the oven says 120/
The model number according to GE says this is an electric oven.
It states that this oven will only be Hard wired and not supplied with electricity using a Plug. If it is gas, only one leg of the 220 volt power will be utilized. and the other usually colored white indicating natural, or green indicating Ground. Or, there will be a switch like on all computers that you will simply move to the selected voltage of the country that you live in and this will correct the high or low voltage. I hope this helps, without the full model # I will not be capable of knowing the actual voltage that the appliance works with.
Sep 14, 2014 | GE JRP24 Electric Double Oven
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Re E90DOa electric double oven. how to connect to power supply?
hi June, although i do not know how to fix the power supply i would like to ask a huge favour. The markings have scratched off our facia panel and we cannot see the temperatures etc. Could you take a close up pic of your dials so as we can use the picture to set our oven. Thanks you so much
nicholaslabocha@googlemail.com
Jun 17, 2012 | New World E90DOa Electric Double Oven
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
My oven will not heat up. the microwave is working fine.
What this indicate can be view from two ways.
1) from the element
2) from the wiring of the fuse the power distributor
You will have to check on the element
and the wire connection from the power supply
Thank you and thanks for using fixya.
Oct 09, 2010 | GE JKP86SHSS Electric Double Oven
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps
Apr 15, 2010 | Bakers Pride P-44S Oven
I need to know which kind of plug is used on this oven so that the electricians can install the right kind of receptacle. Maytag cwe5800acs 24 Double electric wall oven
Your oven needs to be hard wired to a junction box. No plugs on a oven that pulls 30 or more amps 220v Read your install book that came with the oven.
Dec 01, 2009 | Maytag CWE5800A Electric Double Oven
Oven says: ''supply open neutral'' no buttons work what to do?
That means the range is not connected properly, or the power supply to it is not correct. The range needs the neutral (along with one of the hot leads) to supply the 120 volt portion of the voltage required to operate the control. On built in ovens, the red and black are connected to the two hot supply wires, the white to neutral, and the green or bare copper wire to ground. If your supply only has three incomming wires (older homes) then the green (or bare copper wire) and white are both connected to the neutral.
Nov 11, 2009 | GE Profile JT980 Electric Double Oven
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens Logo
94 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
