A replacement kit typically includes instructions. Otherwise check your service manual or search Youtube.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
SOURCE: gas line fell apart inside the fuel tank how do i
The motor and the tank are held together by a rubber mounts or springs which helps prevent engine vibration from going to the handles. These mounts can be unscrewed to allow the separation of the tank from the motor. They are called anti-vibration mounts and should be on your parts list in your owner's manual or on the manufacturers website.
