Question about Refrigerators
Frost on coils
Is there supossed to be frost on the coils when starting it up
    President:
  • 1,136 Answers
THere should be frost on the evaporator coils but not very much. If you need more help, please let me know.
Thanks
Vic
Posted on May 15, 2009
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
Evaporator coil continue frosting\build up ice
check the indoor fan motor, the indoor fan motor has to be running while condenser is on. make sure the filter is clean and the return vents are not blocked. Check charge.
Dec 16, 2009 | Carrier Heating & Cooling
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
AMANA ARSE66MBW SIDE BY SIDE FREEZER COIL FINS GET TOO FROSTED ?
The frost should be uniform on the coils. Uneven frost pattern is a sign of low freon. Most systems are sealed but a qualified tech can recharge the system after finding the leak and cap it off.
Jul 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frost on front grate unit, starting frosting up on thel ittle grates
Dip the thermostat into a glass of ice water. if the compressor stays on you have a bd control thermostat. Clean your coils. use a foaming coil cleaner that is non rinse for indoor use.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 01, 2009 | Frigidaire FAC124 wall/Window Air...
Freezer alarm is going off and water is coming out below our frost free freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Dec 09, 2007 | Refrigerators
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
