Question about Canon PowerShot A570 IS Digital Camera
Blackness? My Canon Will turn on but the screen stays black, any pictures I take are black, and Yes the lens cap is open. The settings still show on the side so the camera is on it just.. stays black
    Problem Solver:
  • 4 Answers
Have you tried reading the instructions? How long did you buy it? Try to press the pad or stick like a button inwards. That is how I get the image to go on my digital camera. Did it work?
Posted on May 14, 2009
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
The screen is showing only part of the picture. A blue line separates the picture with blackness.
REPLACE THE VERTICAL OUTPUT IC & THE 100uf CAP NEXT TO IT.........GOODLUCK....
Aug 02, 2009 | Samsung TXN2745FP 27" TV
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black screen on Canon S1 IS camera
If Canon S1 IS does not show picture in camera mode and show memory card stored pictures in playback then its CCD Imgaer problem and ccd imager will be replaced.
Canon will repair it free of cost, click Canon CCD Imager Advisory for details.
Jun 11, 2009 | Canon PowerShot S1 IS Digital Camera
Camera only takes pics of blackness
you might want to get that checked out or you can try to go to options and pick color then go down to brightness then put it all the way up then get out of that then go to settings and to color and say color on you might just g=have your camera set on blackand white.
May 20, 2009 | Canon PowerShot S5 IS Digital Camera
All pictures taken are just Blackness
is there a view finder on this camera? often when there is a screen and a viewfinder there is a button to toggle between them, my sony camera has such a button although it is not a cybershot. i imagine the button says "dis" or "LCD" and just needs to be toggled. if the display were bad you would not be able to view pictures on it. display works must be configuration issue.
Jan 05, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Flashes, lens open, not plugged in, wont take a picture.
Its is issue of bad ccd imager and this part needs to be replaced for live view to take picture with DSC-T1.
Sony will repair your DSC-T1 free of cost as per announced scheme for ccd problem.
Click Sony CCD Support for details.
Dec 22, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
400D total blackness
Hi, sounds like a shutter problem, try taking a picture in manual mode with an exposure of around 1 second and the aperture stopped right down (small appiture)in daylight.
when you say its not pretty i guess you mean blurred?
If your still getting a black image, take the lens off and put it in bulb and press and hold the shutter release if the shutter dose'nt open and stay open while you hold it then its certainly the shutter.
Its not your fault, all the eos cameras are prone to shutter failure
some are fine for 50,000+ shots others die within a thousand
My fingers are crossed for you that its under warranty.If not a repair in the uk can be done for around 140ukp or $200 in the US, the shutter isn't expensive (about $60) but its several hours work to replace it
Best of luck
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon powershot s1 is
Take a picture and download it to your computer. If the picture is also black, then this might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info (make sure you read the latest reader comments in the first link. You might get very very lucky if Canon fixes this with your model camera :-)
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 18, 2008 | Canon PowerShot S1 IS Digital Camera
Not capturing a photo
Try taking a picture with the camera upside down.  Sounds odd, but it's a possible check to see if the AF mirror is hanging up.
Oct 01, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon PowerShot A570 IS Digital Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
