Question about General Electric WBB2090G Top Load Washer
Spin cycle doesnt work. AND the lid switch is fine.
  • 975 Answers
Check out the pump motor located at on side of the washer , its a small motor with the hose connected to it ,remove it and check for any debris or gunk trapped inside , also check the drain hose, hope this helps , AJ
Posted on May 14, 2009
I have a maytag top lading washer that was working fine. While filling the lid dropped. The only function that works on all cycles is the spin cycle. Can't get any water funtions to work. Suspect the...
What i suspect as being the problem is the lid switch asm....that assambly consist of 2 lid switches and a fuse which is wired through the water inlet valve so if it doesnt fill the fuse it very likely out and the reason the fuse went out is because one of the switches on the asm. is bad causing the fuse to blow.
GENE
Sep 08, 2011 | Washing Machines
When washer goes to spin cycle starts a loud noise, like hiting
you are holding down the lid switch, and being sure that it is heald all the way down at all times while performing this test.
it sounds like the brake is kicking in because the lid switch is being released,
if you are holding the lid switch and it doesnt start to spin, try to assist the basket a bit, if it begins to spin a bit you would need a new clutch because it is saturated in oil. did you notice any oil when replacing the coupling?
but worst case senario would be a transmission.
Jun 18, 2009 | Kenmore 24032\24036 Top Load Washer
2242210 will not spin..wash cycle is fine
Could be several things, but the most common is the lid switch. The little plastic rod on the lid strikes it when the lid is closed. Make sure the switch is not broke. You should hear it click when the lid is closed. If not then it is definitely that.
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Whirlpool ultimate careII spin cycle
sounds as if perhaps a wire is off on the side of the motor assy, l;ook at he wiring harness, sometimes a "chugging " noise occurs form the motor when one of the harnesses is not attached. and yes its normal to wash with the lid open, not to spin however( thats a saftey issue)
Jan 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Doesnt spin out water
Your lid switch is broken.. to check open and close lid a few times and see if you can heard clicking noises.. if not replace lid switch.. good luck..
Jan 21, 2009 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Drum won't spin
check the lid switch plastic tongue mounted some times front--,,lid right hand side,this is a safety measure switch,when lid is open it disables the spin cycle-------tom
Aug 22, 2008 | Kenmore 25842 Top Load Washer
Kenmore washer
Check the lid switch first, make sure when you close the lid the switch is activated with the tab on the lid, if the switch doesnt work, your machine will only fill and wait for the lid switch to be satisified. You should hear the lid switch lick or snap when you open and close the lid.
Start here, if could be the motor or timer, however check lid switch first.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
General Electric WBB2090G Top Load Washer Logo
153 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
