Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
We have a screenplay 61md10/50md10 infocus tv just bought our third lamp for this tv lasted for about an hour someone said might be a ballast issue any suggestions on fixing this problem
5 Suggested Answers
SOURCE: Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
Posted on May 08, 2008
  • 4234 Answers
The flash code indicates that the lamp cover is not installed correctly. There are safety switches built into the housing that require the cover be installed correctly for the set to work. If the cover is actually in place correctly, there may be a broken switch. Check for this and update this if you can not resolve the problem.
Dan
  • 49 Answers
SOURCE: Samsung HLP 4663W DLP TV
If you have already replaced the lamp and ballast, to no avail, then it is time to take it in to a certified repair center.  Most will charge a nominal diagnostic fee.  My 61" did the same thing and it turned out to be the Light Engine (of which the DMD Board is a part).
If the problem were the color wheel, the lamp would come on for a bit until the color wheel sync couldn't be achieved and then it would turn off.  The all-3-flashing-lights problem is the lamp.  Here is a page from the service manual on the 3 blinking lights problem.
The Light Engine controls the ballast via a separate signal than the 320 Volts.  The voltage reading means that the Power Board is working properly.
Posted on Jan 24, 2009
  • 1039 Answers
SOURCE: Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Posted on Nov 04, 2009
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
InFocus projector won't turn on
Sound like either the lamp has prematurely failed or the lamp power supply ballast or igniter has failed.
Jun 01, 2009 | InFocus ScreenPlay 4805 Multimedia...
Lamp on my infocus 4805 keeps blowing. This is the 3rd one.
don't forget to clean your pj all 250 hours of utilisation!!
Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
New bulb installed and it takes 10 plus minutes to start
Exchange the lamp under warranty...
You've tried almost everything else.
It's not that uncommon to experience "infancy failure" with a brand new lamp.
If the problem persists with the replacements replacement then I would suspect the Lamp power supply (Ballast) is failing.
Dec 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
No color
Color wheel disc is broken and not repairable, problem is unless you know someone that can get the part you have to take your projector to an authorised service centre.
Dec 11, 2007 | InFocus ScreenPlay 4805 Multimedia...
Screen going off and on
I Had the same problem. I removed the lamp and found the wires for the cooling fan had got hot and the protective cover missing in spots bare wires were close enough to short Itaped them up reinstalled the lamp and it is now working. Don't know how long it will last so I'm ordering a new lamp assembly.Just in case,
Oct 23, 2007 | InFocus ScreenPlay 61" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
