Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Black strip down right side of page when scan or copy
When I scan or copy anything I get a black strip down the right side of the page
    Sergeant:
    Champion:
  • 240 Answers
Try to align you printer..or print a maintenance pages..
if the problem still persist ...
wipe it on a wet cloth...
Posted on May 15, 2009
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp laserjet 2010 prints black line down side when printing scans from paperport 11
I have no idea what "paperport 11" is.
That being said, normally a line down the page when copying or scanning is caused by dirt on the Automatic Document Feeder glass, Not the flatbed glass. It is a thin strip of glass to the left of the flatbed scanner glass. Clean it.
Jan 11, 2011 | HP Office Equipment & Supplies
Copies are being printed with a line vertically down the side of the page. Only happens when copying using the hopper.
If it's a thin, sharp line, it's just a blob of ball-point pen ink on the scanner glass. Lift the lid, and you'll see the narrow strip of glass that the scanner uses when you feed a document through the feeder. Clean that with a rag dampened with window cleaner, or, better yet, alcohol. Even a dot of ink too small to see will show as a solid black line on anything you copy, scan, or fax via the doc. feeder.
Don't use so much cleaner that it runs under the glass.
Nov 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black strip 1.5 inches wide on right side of page
first, take drum unit out and make sure the blueish-purple colored plastic tab on top of drum is all the way to the left side. if thats not the culprit, then you are most likely looking at a bad contact image sensor or CIS.
hth,
ray
Apr 03, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Black Line when using sheet feeder
Open the cover over the scanning area and check the narrow strip of glass to the left of the platen glass. See if there is any foreign material there (dirt, whiteout, etc) and clean it gently with a damp cloth. You may find a piece of clear plastic covering that area. It's there to keep the glass from getting scratched. If the plastic is heavily scratched at that point, it can cause the line you're seeing. Removing the plastic will clean up the scans.
Jan 16, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Black vertical strip showing on copied and scanned documents
Sometimes this is caused simply by a bit of dirt or dust on a part of the scanner's lens. Since the page is fed through a horizontal "strip" style scanner, something blocking the light on a little piece of it will cause a long black strip all the way down the page.
Here's a guide showing you how to go about cleaning it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&lc=en&cc=fr&dlc=fr&product=3382186&rule=18644&lang=fr
Remember to use a soft, non abrasive lint free cloth! Like a glasses cleaning cloth or a camera/binoculars lens cloth. Last thing you want to do is scratch the glass :P.
Jan 27, 2008 | HP Photosmart C6100 All-In-One Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
173 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
