Question about Kenmore Elite 45986 Front Load Washer
The bellow cracked in 3 spots and when I use the machine, water leaks out. How do I change the bellow? I have the part, just need some instruction. Thank y ou
The bellow has 3 cracks and when I use the machine, water leaks out. How do I put a new bellow on?
  • jkollmer May 15, 2009
    Thank you so much for your immediate response.  Once my husband does the repair, I will advise you how he made out.  Thank you
  • jkollmer May 17, 2009
    My husband was thrilled with the accurate directions on replacing the bellow on my kenmore elite front loader.  Thank you soooooo much!  It really was amazing.  Jkollmer
  • 5,911 Answers
The following link explains all the steps necessary to replace the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions along the way, please let me know. I hope this helps you.
Posted on May 14, 2009
On my Whirlpool Duet Washer the front door bellow is slightly torn and the door won't seal and thus leaks water. I can get the part, but where do I find a diagram or instructions on how to change it?...
The following link explains step-by-step how to change a door bellow on a Whirlpool frontloader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you need some illustrated parts drawings to refer to for additional assistance, refer to the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
If you need any further guidance, please let me know. I hope this helps you.
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Intermittent leak at front. Is there a drain hole at the bottom of the "bellow?"
Appears that the bellows has perished causing a crack which is letting water through.
They are reasonably easy to replace
Jun 24, 2010 | Whirlpool LHW0050PQ Front Load Washer
Leaks water on rinse cycle thru upper vent
Are you referring to the vent on the back of the machine? If your leaking water, you need to replace or install some new mushroom valves. These mushroom valves, go in both bellows on the top of the machine. One bellow goes from the dispenser box, to the tub. This is where the water goes into the tub, to fill. The other bellow, is attached to the top of the tub, to vent. These both have or are suppose to have mushroom valves in them. If they do not, you're machine will leak water out the back of the vent.
Mar 28, 2010 | LG WM2233H Front Load Stacked Washer /...
My ht3 #4292 is leaking water from the door
If water is coming through the door bellow and into the tub and not the floor, this is commonly caused by a water inlet valve that is leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem to determine which one is causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I included parts resources and instructions on how to replace each component as well.
If you have water leaking on the floor, you may also have a bellow with a rip or tear. If the bellow is leaking, it must be replaced. Pull back the rubber folds and inspect the entire perimeter around the door to be sure. If the bellow needs replaced, the following link explains how:
If you have any questions about any of these repairs, please post back and let me know. I hope this helps you.
Mar 11, 2010 | Kenmore Elite 45986 Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
May 04, 2008 | Washing Machines
Whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Nov 10, 2007 | Whirlpool GHW9150 Front Load Washer
Machine leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains). NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them). 2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety. 3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore Elite 45986 Front Load Washer Logo
135 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
