Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
XP Keeps rebooting with LAN Cable connected
Mine is Dell Dimension 5150 Desktop PC.
Recently it statred behaving strange.
1) It stays in restart loop with LAN cable connected. The PC runs until the windows login. Once after login it restarts immediatly. But if you remove the LAN cable, It starts normally and no problem.
Here is what I already tried,
1) I thought it could be a virus and did full system scan with Norton Antivirus. No Virus found.
2) I tried to boot without LAN cable and inserted the cable after successful booting. As soon as I connect the calbe, the system reboots. If I have the LAN disabled before connecting the cable, it dosn't reboot. But as soon as I enable the LAN it restarts.
3) I did complete system restore to the factory original condition. No sccuess. The problem exists.
4) I removed all the external cards I had(External PCI Video Card, Wireless LAN PCI card). Still the problem exists.
5) I removed the CMOS battery and replaced. No Success.
6) Installed the LAN Driver again. No Success.
Anbody have the solution for this. Pls help!
Thanks,
  • bnachimuthu May 15, 2009
    Hi Martin,
    Thanks for your response.
    Do you mean Wake On LAN?
    Let me check my BIOS setting and try to disable it and see.
  • bnachimuthu May 18, 2009
    PROBLEM SOLVED!!!
    All I did was running a Dell Diagnostics download from Dell\support.
    It took about 1 hr to complete the whole diagnostics. After completing it did not report any problem. But my restart issue went away and PC running normally for last 3 days.
Hi banchimuthu ,
this restart problem is spyware problem,you can solve this problem by combofix& sdfix
Posted on Aug 06, 2009
  • 39 Answers
Have you tried going into the bios setup before windows loads up? You may have a setting to choose startup on lan. Just turn that off and hit F10 and enter.
To enter the bios setup keep pressing delete after truning on the computer until the bios screen appears. Don`t change anything unless you know what you are doing.
Posted on May 15, 2009
  • martin_a_jen May 15, 2009
    Once on the bios screen you need to go to the advanced bios features. Once there go to power management and you will find the entry for lan and can disable it. Bear in mind that you bios display screen coudl be a little different to mine but if you look aroudn you will find it.
    Good luck
Dell 5150 dimension; windows XP sporadically reboots on it's own.
Best thing to do Lou is to reinstall windows XP. this should take care of your problems. Best of luck.
Apr 09, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I'm looking for advice on how to reboot a dell dimension 5150
You can reboot by Operating system , Click start>Restart
OR
you can press power button for few seconds, it will power off, & then you can press power button.It will start booting up...
Thanks for choosing Fixya
Mar 16, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
We have BT broadband. When we occasionally have to reset the router, everything except the 2 Dell Dimension 5150 desktops works via wireless. They refuse to reconnect. All the other Desktops / laptops work...
Not sure exactly what your hardware setup is, but I would reboot the broadband router, then reboot the wireless router. Everything should come up clean, but give it at least 5 min. To help connect after reboots, you can choose "repair" from the wireless icon in the system tray (XP?) or renew your IP address. Start --> Run... and type ipconfig /renew
Hope this helps!
If so, please leave a rating!
Mar 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 Boot Problems!
You can probably try two things here.
1) Go to the BIOS and reset the defaults.
2) Clear NVRAM from your Dell computer. Here is how you do it.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=4C1BF720A3E78F92E040A68F5A2811BE&journalid=7788D9829DCAA7C8E040AE0AB6E12FA2&Query=bnZyYW0=&SystemID=DIMENSION+5150/E510&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer wont start up!
try to replace the IDE/SATA cable connection..good luck
Jun 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Need a reboot disk
Does it have a Microsoft sticker on the case giving you a serial number and product type: 2000, XP Home , XP Pro etc
If it has one then you need to find a buddy with a copy of that software and hope that it is compatible with the version you have on your system.
If not then it is off to the shop for a fresh copy
Jun 02, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Start up Problem
hi carlogb,
1) dissconnect any external hardware like usb devices, modems, card reader, etc and try to restart windows.
2) If 1st step doesnt works, open the chasis and check all the cables are connected properly or not. Reseat all the cables if possible.
3) If 2nd step doesnt work, remove the cards like lan card or any other pci cards from the motherboard and restart computer again.
regards,
TheAssembler
Jun 06, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
325 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
