Question about Cakewalk Music Creator 4
Can't record vocals
Is there a certain mic you have to use to record vocals on cakewalk 4
  • 39 Answers
You can use any mic you want but you have to go to the soundcard mixer and enable the source for recording from the recording properties. If you have a separate soundcard not the onboard one usually it will have it`s own mixer software so you open that up and set it to record from the microphone input if that`s where your mic is inserted. If you use the onboard sound card then go to control panel - sound and select the device you want and also set the recording source. In sonar you have to right click on the track in the left part of the screen. This brings up the properties for that track. The you select the sound card input and output for that audio track.
That shoudl solve your problem.
Of course you will get a much better result if you use a good mic plugged into a mixer or pre amp and send the source into the line in of your sound card and adjust the rest accordingly.
Posted on May 14, 2009
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
Art Tube MP Project Series preamp how to set up comp to record
USB option does not work at all q as they said....Their use manual only makes marketing...It is not nice.
if I ask simple step by step. What is problem with it?
I fed up to use USB option ( no rec signal ) on this unit cause I have been told, better to use Yamaha mix device....
best.
V.
Sep 29, 2009 | Dual ART DPS II Preamp System with Tube...
When I load up my beat & try 2 record, It stop by itself!!!!!!!!!
Tyke, This is likely an issue of your CPU. This usually happens when you don't have enuff horse power (if u will) in your system. Audio engines take a TON of power to run, and depending on your settings and where u have your latency buffer set- you can easily get drop out. You should definitely check this:
http://www.cakewalk.com/support/kb/kb2003175.asp
but u might wanna change u're latency buffer first. think about your cpu speed and what other programs are drawing power.
Jan 17, 2009 | Cakewalk Music Creator 4
C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Input Echo - audio feedback loop
do you record from
a) mic
or
b) line input ?
if a)
turn off your speakers, and use headphones.
or at least turn down the volume, and change the mics position (as far away from speakers as possible)
if b)
dont route the allready recorded channels to your master while recording (-> or mute them)
Feb 09, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Playback is faster than recorded
close that windows
now click on it again (left click) and choose mixer
Does your mic show up there ?
Jan 11, 2008 | Creative Labs Sound Blaster Audigy LS...
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Cakewalk Music Creator 4 Logo
165 people viewed this question
Top Cakewalk Computers & Internet Experts
Dan Shibata
Dan Shibata
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
