Question about HP OfficeJet 7410 All-In-One InkJet Printer
Driction of dobulesided printing. Suddenly the front side prints correctly and the backside prints in revese direction.
Where are the contols for the automated dobule side feeds? My documents print frontside up backside prints down.
  • stevemidpk May 15, 2009
    Still can not reverse print direction. Frontside one way backside upside down.
  • 696 Answers
To adjust these controls open you start menu, then control panel. Click on classic view, then click into printers.
Right-Click on your Printer and select properties from the grey menu.
Select Priniting PrDriction of dobulesided printing. Suddenly the fro - 77d121f.jpgs in the picture.
OnDriction of dobulesided printing. Suddenly the fro - 8a24dcf.jpgng shortcuts menu ensure you have double sided printing selected then:
Then got to the advanced tab and click on the page order selection, once you click it a list will pop up with Front to Back and Back to Front listed. Click the one you want and then OK out of both windows.
Hope this helps FixYa,
Chris
Posted on May 15, 2009
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Stopped printing envelopes in proper direction
What software are you printing from? It sounds more likely to be software causing the issue.
Sep 05, 2007 | Brother HL 1440 Laser Printer
Printing in black mono only. A portion of the
Common problem is a dirty card, make sure you handle the cards by the edges and not the surface as oil from finger residue will cause a misprint on that part.
This problem can also be caused by improper or too low of a setting for black intensity, where the printer does not apply sufficient heat to transfer the color onto the card.
Also check for a faulty ribbon, if the ribbon is not properly stored or is more than 3 years old, it can also cause this issue.
-- The Pros at www.DiscountIDStore.com
Nov 12, 2010 | Zebra P330i Thermal Card Printer
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Feb 23, 2010 | Evolis Pebble 3 ID Card Printer Package...
Dulex printing???? for HL 2040
The way that I know to do it is to indicate that you are going to manual feed when printing. hit print
Then feed the paper into the manual feed slot, noting the correct direction in the diagram in the paper feed area. Once the first side prints then feed the paper through the manual feed slot, again following the directions in the diagram.
Feb 13, 2009 | Brother HL-2040 Laser Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
I have a Canon mx310 printer. I have read the book but can't find out if I can print on both sides of a piece of paper. If it can be done can you explain how Regards Ted gray
I just read the data on your model and it says nothing about two sided printing.
You can still print two sides of the paper with any printer. Save page 1 and page two sweperately. Either place one piece of paper into your printer or if it feeds for the front of the pile ,Just have it print side on. After that is done the the printed paper and place it back into the the front of the paper tray so that it will be the next one printed,then print side two . A slow poocess but sometimes worth it. (You may have to turn the paper around and or backwards for it to print on the correct side in the directing you desire, experiment).
Dec 21, 2008 | Canon Office Equipment & Supplies
Hp 920c tech support
check your print cartridge has not plastic strip stuck on bottom side of it.
recoonect all connection then try.
Nov 24, 2008 | HP DeskJet 920c InkJet Printer
Printer suddenly stopped printing
verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
or
1. delete the installed driver
2. turn off the printer and let your computer detect the printer.... let it finish
3. restart your computer
Nov 09, 2008 | HP LaserJet 1020 Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
