Question about Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 jams paper after each copy what is the problem.
My MFC 7420 jams paper every time I use it and I have to open and remove paper. What is the problem and how can I fix it.
Thanks
Fred
  • seyc May 11, 2010
    Where is the jam? Does it jam when being picked up? Does it jam before or after the drum? Does it jam between the drum and the fuser? Does it jam after the fuser?
  • 133 Answers
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
Posted on May 24, 2009
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Paper jam
make sure ur paper lined up and in the right angle
Dec 31, 2012 | Brother MFC 7420 All-In-One Laser Printer
First of all I have a paper jam, one sheet got stuck after I tried to make a copy. Since then every time I turn on the printer it won't print or copy, of course the sheet is still stuck. I get the message:...
hello
first open the front cover remove the toner of the printer and remove the paper jam, and turn off the printer, unplug the power plug from wall outlet and at the back of the printer and after 2 minutes plug it back and turn on.
thank you
Mar 07, 2011 | Office Equipment & Supplies
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 keeps saying - back cover open - close thre back cover? How do I reset the printer orf find the underlying fault?
First be sure you close the back cover and remove all the jammed paper. after that, turn off your printer for 1 min to see is it okie.
Jun 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jamming
tell me where it jams so that i may help you! brother tec
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
I have a Brother MFC 7420 with a bad paper jam in the back
white knight to the rescue. the back door is quitew tight to open. pull it open with a firm **** of the hand.there you will see the paper jam. pull the paper out slowly as not to break the paper sensor in the back. let me know how it went. brother tech
Dec 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
1,581 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
