Question about Lexmark X5150 All-In-One InkJet Printer
5150 lexmark printer does not print.goes thru the motions but does not print.installed two new cartridge.
  • rljsr35 May 14, 2009
    I have no clue to your answer.Is there any other possible answer??
    x5150 printer goes thru the motions but does not print.
    Novelist:
  • 130 Answers
Click the properties of the printer ,then go to lexmark solution center ,there you get your cartridge selected as new.as now what has happened that you have installed the new cartridge,but actually your printer is not knowing that new cartridge is installed,the printer memory has just in mind that the old empty cartridges are still there.so its not printing just motion.get your cartridge selected.-------------- but you fiond it dufficult and nothing is helping you then one simple solution.take your printer driver cd and reinstall the prionter drivers,in that it will automatically set all the settings for this time.next time again when you replace the cartridges reinstall the drivers again. ------------------- if by chance you dont have driver cd dont worry click this link and get the latest driver cd of your printer  http://www.pcdriverdoctor.com/printerlisting/printerdownload/lexmark_x_5150driver.php
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 14, 2009
  • 315 Answers
  1. Remove and reinstall the printer driver.
    If you are using a service pack, reinstall the service pack after you reinstall the printers.
  2. Check the available space on the hard disk. Print jobs may not print if there is not enough space to spool the print job.
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
I bought lexmark 2200 all-in-one second hand.I've loaded software twice but still printing blank pages.It says both cartridges are full. Could this info be wrong? I hate to buy new cartridges if printer is...
Is this a genuine lexmark cartridge? If so, please take it out and use a tissue paper to cover the bottom part and give the cartridge a gentle shake.
Then clean away the ink and put it back in.
Aug 15, 2010 | Lexmark X2250 All-In-One InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
I have 5150 it has full black cartridge not much color almost out I want to print in black and it will not goes trough the motion not print though just light blue.
Your description of the problem means that in your word processor you have specified color printing. Here you must change it to B&W. Then it will print black. Also do the same in Print manager.
Dec 11, 2009 | HP DeskJet 5150 InkJet Printer
I just installed two new print cartridges, I printed two photos and now it goes throught the motions of printing, but there is no ink on the page.
Did you remove all the packaging from the cartridges? Are you certain? Absolutely certain? Please check for me anyway.
Please let me know what happens
thanks for your interest in FixYa.com
thanks
a
Dec 06, 2009 | Lexmark X1240 All-In-One InkJet Printer
Put in new cartridge and unit will not print. Goes through all of the motions but doesn't print. Printed many pages before "low on ink" message. Why does it not print now?
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Sep 04, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Will not print
Try printing a test page from the printer. If you have the same problem, your cartridge is cloged or bad.
Mar 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 5150 - Error 0502
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
