Question about Xerox Phaser 7750DN Laser Printer
Grainy image quality on my Phaser 7750
I am experiencing poor toner coverage in my Xerox 7750. I have replaced imaging units and toner all with Xerox OEM parts. No joy. Any other possibilities?
  • mguttery May 15, 2009
    Is a thick brush a good or bad thing?
    President:
  • 2,072 Answers
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
Posted on May 15, 2009
  • Rick Kasper May 16, 2009
    A thick brush is what you want.
Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 7750 The printer's black fades print after print and totally vanishes. I tried replacing Imaging Unit, Toner, cleaning by wand, etc.
If it is only happening in black then it has to be something prior to the toner reaching the transfer belt; such as toner, developer, imaging unit, or laser. It sounds like you've already cleaned the laser window, replaced the toner, and image unit, so I would inspect the developer. Remove the black image unit and use a flashlight to inspect how well toner is covering the magnetic roller on the developer. You may want to compare it to a developer of a working color to see if they look similar. Also, make sure there are no foreign objects near where the image units go. If an object came loose in there, the arm will not close correctly which could cause the image unit to not make contact with the developer. Hope this helps, and thanks for using Fixya.
Sep 17, 2011 | Xerox Phaser 7750GX Laser Printer
Can i reset the imaging unit on my phaser 7750
There is a chip in the bottom of the image unit which stores the image unit life. These can be reset but it requires special hardware and software to do it. You can also buy replacement chips, they're usually about $50 for a 4 pack and you can find them on e-bay. Rechipping with out replacing the entire image unit will result in lower quality prints though.
Aug 09, 2011 | Xerox Phaser 7750DN Laser Printer
Says we need a new imaging unit, is there a way to trouble shoot before ordering??
The imaging unit has a CRUM which records usage. It has a life span of approximately 30,000 prints based on an average 5% coverage, so it is possible for one to become end of life at 5,000 prints or less if it has been used for heavy coverage.
Unfortunately the imaging unit is not re-settable but in my experience the Phaser 6125/6130 units are prone to giving print quality issues so it is advisable to replace it if showing end of life.
Hope this helps.
Jan 20, 2011 | Xerox Phaser 6125 Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
I have not used my Phaser 6110 for about 3 months, and now print quality is bad. It appears to be only the black that is affected. print quality is faint although slightly darker down one side. I have...
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
Nov 24, 2009 | Xerox Phaser 6110 Laser Printer
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Print quality problems after installing imaging unit.
Put the old image unit back in, if it prints normaly then you might have bought a defective image unit.
Apr 16, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
532 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
