Question about Panasonic TH-42PWD5UY 42 in. Television
Breakout cable usage
I am attempting to use a rgb component to hd15 cable from a directv hd dvr. I tried to use an existing cable i have which is a hd15 to 5bnc cable but the picture was green with some red and blue. I am currently viewing the tv using an component cable from the receivers rgb to the tvs rgb with quite a good picture. Only minor flicker when changing channels. I would like to know if i use the hd15 to 3 rgb cable, would that correct the green effect? I was told that the h&v is intergrated in that cable.
  • 4 Answers
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Posted on Jan 23, 2008
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV GenieĀ® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your GenieĀ® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
How do i connect my directv box to my soyo tv #DYLT032D
  • If your DirecTV box supports HDTV then connect it using either an HDMI cable from the box to the TV (located on the back, labeled HDMI 1,2,3,etc.).
  • If the box is not an HDTV box then connect it with a RGB (red, green, blue) composite cable from the box to the TV.
  • If the RGB output is not on the ack of the box then connect using a standard coaxial cable.
[NOTE] In order for the quality of the picture to be HD, use the RGB for digital (Better), or the HDMI for High-def (Best)
Mar 02, 2011 | Soyo DYLT032D 32 in. LCD Television
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
Won't record in HD. DVR shows to be recording, but when you click on the programmed HD channel (the one that's supposedly recording) it's blank and says "searching for satellite". Just started recently.
Have you tried rebooting the DVR and removing the card that came with the DVR if its one that was provided to by one of the satellite company's such as Directv or Dish.
Nov 30, 2009 | Directv HR22 500-Hours HD DVR
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
Panasonic TH-42PWD5UY 42 in. Television Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
