Question about Garden
Engine stalls when giving gas
My ryobi 31cc weed **** idles fine but when I give it gas it bogs down and stalls. If I let go of the trigger it will go back to idling fine. I took the carb off and cleaned it the best I could. I am using fresh gas 32/1 mix and a new spark plug.
  • got_mj May 16, 2009
    I checked the fuel lines but still am having the same issue. Any other thoughts?
  • 41 Answers
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
Posted on May 15, 2009
  • Ragoo Monistere May 19, 2009
    If it is still stalls or bogs, replace carb. Sounds like its in carb. and not fuel lines.
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi C430 stalls when I try to give it gas. It idles fine though.
remove the muffler and try it if ok with out it open the muffler and clean off the internal screen
Apr 04, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
MY RYOBI S430 WITH THE EGDE ATTCHMENT WILL NOT RUN UP TO FULL SPEED. IT BOGS DOWN AND STALLS. RUNS FINE WITH THE WEED EATER ATTACHMENT. THANKS RON
too much drag on the edger, try putting some oil or lubricant spray where the edger spins on the attachment.
May 03, 2010 | Garden
Blower shuts off
replace the diagfram in the carb it easy
Aug 21, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
31cc Ryobi weed eater engine will start, then stall shortly after
you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
May 24, 2009 | Black & Decker 19" Electric Lawnhog...
The trimmer will not run when i give it gas
When 2 cycle engines preform as you have stated...the main problem is a carbon build up on the spark arresting screen on the muffler, it needs to be cleaned or replaced with a new one
Apr 04, 2009 | Garden
Bad Carb
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Aug 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
1,348 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
