-   as much things as i try i cannot open it....many sites say if you use a paperclip to press a button it will open...where is that button??
-   kristapuss52
If the eject button on the faceplate doesn't work there are two other ways to open it.
1. Open My Computer, Right-Click the drive, then select Eject from the grey menu.
2. get a paperclip, straighten it, then insert it slowly and gently into the small hole in the DVD faceplate. when you feel the switch, press in with gentle preasure then back out. This should release the drive lock and it should pop open.
If neither of these two solutions works there may be a bent lock or a disk jammed in the drive. You will have to identify the set screw on the bottom of the laptop that holds the dvd then remove the screw and slide it out, then retry step two while giving the faceplate a bit of preasure.
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,...
(More)
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed, I hear the noise of opening mechanism, but the actual plate doesn't come out. Tried to open HP Solution Center, but got the following message: Parsing error in file C:Program filesHPDigital ImaginginhpqsclocC3.xml
Information on NEW CD's does not download. It used to until my last service update. What have they...
(More)
Information on NEW CD's does not download. It used to until my last service update. What have they done? I'm running Windows Media Player 10 because I can edit DVD & CD files on screen!
my acer 5100 series will burn anyWHERE FROM 2 TO 5 songs then the rest will have errors and i know...
(More)
my acer 5100 series will burn anyWHERE FROM 2 TO 5 songs then the rest will have errors and i know theres nothing wrong with it can u help me jason
