Question about Garden
Gas shoots out of carb cannot stay running ,troy
The gas runs out of the carb,when I give it gas it runs then shuts off.
  • 31 Answers
Float is sticking on carb. try tapping on it lightly with a wrench
Posted on May 15, 2009
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
May 27, 2014 | Troy bilt Super Bronco Tiller 208cc
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed eater will idle but shutdown upon giving gas
Cleaning the screen on the muffler will help but the muffler itself is what needs burned out. This can be done with a fire or a torch. Let the muffler cool on it's own as use of water can warp it. Parts can usually be purchased at any small engine repair shop that represents Mtd. That's who make the weed eater.
Jun 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
