Question about Sony PlayStation® 3 (80GB) Console
PS3 static on screen
Ok, I have an LG 32" 1080p tv. It has a PS3 hooked up to it through an HDMI cable, the PS3 is set to 1080p and it looks like i have static on the television, this only happens when the PS3 is sending out a 1080p signal, when i change it to 1080i the static goes away. The static also goes away once you put a movie in as well. The static looks like when your cable signal is bad on your tv, not completely static, but some. I have tried 3 different HDMI cables, and all did the same thing except the $100 monster cable my friend let me use, and I really don't feel like spending that kind of money, does anybody have any ideas? Thanks!
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
Posted on May 14, 2009
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
No signal from ps3 to lg tv via hdmi
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Aug 20, 2009 | LG 42LC2D 42 in. LCD HDTV
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Can't play PS3 on LG 42LC7D tv
use hdmi cable from ps3 to rear of tv (you should have hdmi 1 & hdmi 2)then ppress input on remote until you get hdmi 1 or 2 on screen walaa
Dec 20, 2008 | LG 42LC7D-UB Television
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
HDMI causes red lines (static?) on screen
im having the same problem to fix it i unhook my cable box (the video cables and the hdmi inputs to the tv) this stops the lines--try just the ps3 hooked to the tv and no other devices this should solve the problem--must be getting interference from some device
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
623 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
