Question about Frigidaire 24 in. FDB421RF Built-in Dishwasher
Door dropped Opened door on my FDB421RFR and a loud cracking noise occurred - now the door drops quickly. I guess the spring(s) have broken - does anyone know if the spring is on the rhs looking at the front? I sure hope so, I can probably access that side without pulling the unit out! Is it good to spray these with WD-40 or do they just age anyway?
3 Suggested Answers
SOURCE: Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Posted on Aug 24, 2009
Testimonial: "Hey, thanks for the advice. Worked like a charm. Hopefully Frigidaire has improved their design."
  • 246 Answers
SOURCE: front door opens too fast.
I am not exactly sure how to correct the problem of the door opening too fast but if you are ever looking to change the appearance of your appliances then check out www.applianceart.com
these guys have lots of options available even stainless steel.
Posted on Feb 22, 2011
Door doesn't open slowly, it drops down suddenly when opened. What is the problem please?
Pull the dishwasher out. You may see the mechanism and possibly broken spring or other part. (possible it's just come apart. You may need to remove side panels to see this mechanism for the door (counter balance) .
Apr 11, 2015 | Dishwashers
Loud popping noise occurs when refrigerator door is opened
of course not! you paid good money for that fridge! can you train everyone to open the door only to 85 degrees?
Mar 08, 2013 | Refrigerators
We have a built in diswasher MDBH969 AWQ which is less than 2 years old. Suddenly the Door to the washer drops down quickly rather than what appeard to be spring loaded and would drop slowly before.
Bbeldenjr, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Bbeldenjr), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 23, 2017 | Whirlpool MDBH969AWS Builtin Dishwasher
The door on my frigediare dish washer is all of as sudden very loose the spring is still in place can the spring just get weak?
The spring should take the weight of the door to prevent it from dropping hard when opened. There are two springs so one of them might have broken. One on each side.
Jun 09, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
The door to our Kitchen Aide dishwasher now drops down very quickly and it used to have some control when the door was opened.How difficult is it to repair?
Hi, it is likely a broken door spring, or both. Part number 9743986. You can access them by way of removing the screws in the toe panel below the main door panel. Be sure to shut off the power to the unit. With the toe panel removed you should be able to visually inspect for a broken spring, with the aid of a flashlight ot trouble-light. One hook will connect to the hinge while the other end hooks into the dishwasher frame towards the back. Hope that help's and thanks for visiting fixya. Please take a second and rate the solution provided for here today. Good luck. Macmarkus :)
Dec 25, 2009 | KitchenAid Dishwashers
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
