Question about Bob Mackie SRM350 Main / Stereo Speaker
Mackie swa1801, thermal light flashing while in use ????
I just would like to know what i need to do when this themal light is flashing while i am using them. There is plenty of ventilation around speakers too. Should i send them somewhere to get checked out or can i do something myself? same problem and no signal at all
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
Components Q12 & Q13 (2N 3906) PNP transistors fried. Would there be anything else blown?
It is sad your having a problem with Q12 and Q13, check the regulator
that supply voltage on the transistor 's your referring to.
Q13= 2SA1478 for Mackie SWA1501 Active Subwoofer
the supply is about +15V and -15V
Aug 20, 2012 | Mackie SWA1801 Subwoofer
No power
There are about 6 fuses on the inside. check them but the amp is probably blown
May 26, 2011 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Jul 01, 2010 | Mackie SWA1801 Subwoofer
How do you get to the ac fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
May 13, 2010 | Mackie SWA1801 Subwoofer
Swa 1801 mackie blown capacitor
Took alot of finding but you can get them from Digi-key
Sep 16, 2008 | Mackie SWA1801 Subwoofer
How to open SWA1801Z
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Jul 01, 2008 | Mackie SWA1801 Subwoofer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Bob Mackie SRM350 Main / Stereo Speaker Logo
185 people viewed this question
Top Bob Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bob Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
