Question about Mitsubishi HS-U545 VHS VCR
VCR will not switch to program mode
My Mitsubishi hsu-54 will not switch to program mode. When I turn TV to channel 3 and using the reomote, turn on VCR and switch to VCR, I cannot get the VCR to go to the mode where you can select what you want to record. The remote does play the tape but nothing else seems to work. The batteries in the remote are new. I realize the VCR is old but was working until just recently.
Please help!
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
Posted on May 15, 2009
We have a 4 head hsu 110 vcr. the inputs for the aux cables are not color marked so we're just wondering where the cables go. thanks! peace
The HSU110 doesn't have stereo audio jacks. It has a one audio and video input jack and a similar audio and video output jack. The input jacks are at the top and the outputs are below. The video (using the AV RCA yellow) jacks are on the right of the set of RCA jacks. If you connect this to a TV with stereo audio, pick either the left or right channel on the tv to connect whichever wire you connect to the audio out of the VCR.
The manual for the Mitsubishi HSU110 is available at http://www.managemylife.com/mmh/owner_manuals/25789/MITSUBISHI-VCR-97110132 .
I hope this helps.
Feb 22, 2011 | Mitsubishi Televison & Video
I need my codes for Mitsubishi tv so i can program my philips universal PM335 large button remote
Hello
Three digit universal remote codes for Mitsubishi are
004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
Four digit universal remote codes for Mitsubishi are
0005 0151 0051 0004 0009 0254 0022 0141 0180
There are two ways for direct entry.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
1. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
2. Press and release the desired mode button (TV,
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
indicator flashes.
Note: If some buttons do not operate your equipment,
NB: Switch OFF and switch ON your TV with its front panel power on/off button each time before trying an other code.
OK.
Feb 12, 2011 | Televison & Video
What is the universal remote control code for this TV
Hello
Three digit universal reomote code for Syphonic are:-
520 904 906 033/ 053/ 189
Four digit universal remote code for Symphonic are:-
0053 0189 0227 0456 0024
Direct Code Entry
NB: Switch OFF and ON your TV with its front panel power switch [NOT BY THE REMOTE CONTROL HANDSET]; each time before trying and other code.
OK.
Dec 22, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
Jan 03, 2008 | Polaroid PDM-1058 Portable DVD Player
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Mitsubishi HS-U545 VHS VCR Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
