Question about Brother PC-6000 Pacesetter
Brother Pacesetter 8500 touchscreen doesn't work
The touchscreen comes up with a picture of 2 threads to make the LED display lighter or darker. You're supposed to adjust this, turn off the machine and restart to go to the regular Disney sewing screen. The machine is not responding to any touches and when I restart it, just comes up with the same LED screen. Tis has happened before but has righted itself after a few turnoffs. Help!!
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Thread looping onto itself
when i try to pick up the bobbin thread it does not pick it up at all i even try threading it all back over many times can yuo help me please
Posted on Oct 06, 2008
  • 19 Answers
SOURCE: Thread from bobin doesn`t leave smooth sewing on bottom of fabric
hi make sure pressure foot is raised before you start to thread machine ortherwise thread will not slide between tension discs this will cause bunching underside of fabric ...good idea to replace needle good luck
mary h
Posted on Jan 05, 2009
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
My touch screen isn't working
Brother 8200 8500 8500d screen ..just found this on youtube not sure if this will help you out
Dec 03, 2016 | Brother Sewing Machines
Why does upper thread break?
Check your tension, especially the tension disks for loose thread. Then rethread the whole thing.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Pc-8500 how to calibrate touch screen
ADJUSTMENT
match.
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Upper thread keep breaking
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_PC_6000_EN_2572.PDF manual is at the above web site
Jan 26, 2014 | Brother PC-6000 Pacesetter
How to thread a pacesetter sewing machine?
There are different models of the Brother Pacesetter.
If you try the Brother website you should be able to download a manual.
Apr 01, 2010 | Brother Lay-In Thread Serger Mechanical...
How do you thread a brother pacesetter 6000 for twin needle sewing
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
May 02, 2009 | Brother PC-6000 Pacesetter
I have a pc-8500 and the top thread breaks constantly. I have taken the side off...and see no thread tangled inside...as well as haven taken off the bobbin plate to make sure there is no thread tangled...
OK. I was just being kind of an idiot. I replaced the bobbin spool with one that came with it and it's working fine now. Apparently this machine is very picky about the type of bobbin you use.
Nov 05, 2008 | Brother PC-6000 Pacesetter
Sewing Machines Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
