Question about American Audio DCD-PRO310
I'm have'n a problem
Well i'm try'n to connect channel 1 and 2, but don't know where it goes
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Posted on Jan 06, 2008
The channel 1 the light red is on
As always with stereo amps the two channels are identical, so if one goes wrong you have the other as a control for testing purposes. So if you start by looking and comparing the two channels. that's a start! If a part looks odd on the faulty channel, but is fine on the good channel you have found the problem. You can also do tests, such as touching the two channels with an insulated screwdriver, while powered up. If it buzzers on the good channel, it should buzz on the other channel at that point. Keep away from the power supply and ignore anything that is on it's own, that has no duplicate, or is common to both channels.
Feb 10, 2014 | QSC GX5 2Channel Amplifier
The problem of my guestlink tv is that when tune in to a channel it goes off after some minutes and how to operate the remote control of the model NX63L1.
You can Google the model number with "manual" to try to locate the owner manual---as far as other problem does a DVD etc do the same thing when connected to a rear audio/video input? It will narrow things down and offer possible choices.
Jun 07, 2012 | Televison & Video
I want to know the correct method on how to do a SWR test with the Galaxy 959.I have a 5 foot self adjustable firestik and have mounted it to a 4mm thick aluminum plate 30 cm square and will have it higher...
The best way is with an antenna analyzer but that is too expensive unless you do SWRs for a living. The meter on the radio should suffice for your needs.
Adjust the screw on the antenna until it is about 1/2 inch out.
Place the srf/swr switch to swr.
Go to channel 1 and note the SWR reading on the meter.
Go to channel 40 and do the same.
If channel 1 SWR is higher than channel 40, then screw the tuning screw out a turn or 2.
If channel 40 SWR is higher than channel 1, then screw the tuning screw in a turn or 2.
Repeat until the SWR on channel 1 is the same as 40. Channel 19 will be the lowest.
If you are not comfortable using the built in SWR meter, you will have to invest around $20 for a small SWR meter.
,,,,Don at NTCB, Inc.
Jun 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Hi not sure if i can stay connected long enough to ask ? i am using a desk top pc i using the belkin dongle that came with the router its allways losing connection i have tried all sorts of options that...
If you are using WPA2 encryption, try reconfiguring it to just WPA.
Also, if it fame pre-configured for channel 6 or 11, reconfigure for channel 1 or 10...this often helps a lot if you are in a highly populated area.
May 27, 2011 | Belkin Basic Wireless Router
I'm trying to connect my Wii console to an old magnavox tv my aunt gave me. I don't know how to connect it because it doesn't have the tv/video button on it. I've tried reconnecting...
U have the tv original remote?Look for a button said Input,used that button push it to goes into video mode 1 or 2.Don't have the tv original reomote.Try website like Remotes.com to buy the tv original remote.
May 08, 2011 | Televison & Video
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
My toshiba tv only goes up to channel 12, when it reaches channel 12 it starts back at channel 1.
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
Nov 20, 2009 | Toshiba 36A40 36" TV
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Jul 26, 2009 | Sony RDR-VX535 Player
Zenith TV
have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Dec 28, 2007 | Televison & Video
Xplod amp
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Sep 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
American Audio DCD-PRO310 Logo
119 people viewed this question
Top American Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
