Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My computer will not longer reconize jump drive and it heats up when plugged in.
My computer will no longer recognize the jump drive and seems to heat up when plugged in.
    Sergeant:
  • 186 Answers
Please try with some other PC or Operating system.
If you didn't succeeded then may be you lost ur drive !!!
Posted on May 15, 2009
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
Why wont my wd media player reconize my tashiba external drive
check whether the folder of you wd hard drive are hidden
Feb 03, 2013 | Computers & Internet
I have 2 lacie external hard drives that no longer work. They power up and I can hear it working, but they are not reconized on any computer.
Chances are, the IDE/SATA to USB/Firewire controller inside the device has died. You can take the case apart and take the hard drive out, and plug it directly into a computer through IDE or SATA, whichever it is. If the drive is recognized, then all you need is another external case to put the drive into. If it isn't recognized then most likely the powerboard on the hard drive or some other internal mechanical part is dead, and you would need professional data recovery to get anything off of it that you would want.
Apr 30, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Computer no longer recognizes my Sony Walkman NWZ-E4365. I have attempted to update drivers in device manager to fix, no dice. Within the device properties I receive this message: Windows cannot start...
Unplug the power cable from the cpu, and all usb devices, let it sit for about 10-15 mins... then plug everything back in and start up computer... see if itll recognize it...Try all usb ports also.
Aug 12, 2009 | Sony Walkman NWZ-S616F MP3 Player
Dvr no longer recognizes hard drive
Try switching around some wires.
If that doesn't work then it might be damaged.
I suggest plug it into another computer to see if it still works. Find out if it's the hard drive or the computer.
Jul 10, 2009 | Computers & Internet
SimpleTech not reconize by my computer.
hi there,
i will pass on what was given to me for information. if you are still getting power to the drive you can remove the external casing, remove your pc side panel, where you would insert memory and plug the hard drive into the tape inside your pc to see if the pc will recognize the hard drive. if you are not getting any power or platters spinning then it is more serious. i wish you all the best. cherie
Mar 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Pleomax 6gb USB Drive No Longer Recognized by My Computers
It's either the USB port, the drive electronics itself, or the USB cable.
First I'd try a different USB cable.
Apr 06, 2008 | Computers & Internet
Toshiba 4mb jump drive
try to jump from one usb slot to another until your computer recognizes your flashdrive.
Mar 25, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
224 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
